You're welcome 👍
OS Build 19045.4957 Quality Updates (50) 2025-02 Cumulative Update for Windows 10 Version 22H2 for x64-based Systems (KB5051974) (2) Failed
OS Build 19045.4957
Failed to install on Mon-Mar-03-2025 - 0x80070002
Either KB5050593 or KB5050188 currupted my ability to edit txt and bat files.
2025-01 Cumulative Update Preview for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050593) Successfully installed on Mon-Mar-03-2025
One of these currupted my edit txt and bat command
2025-01 Cumulative Update for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050188)
I tried all the work arounds and that didn't work.
61 additional answers
2025-03-14T20:47:03+00:00 Please try from WinRE, The 3rd option in this link. https://pureinfotech.com/reset-pc-keeping-files-windows-10/#reset_windows10_winre
If that doesn't work, you may backup the data to external drive and clean install Windows 10 using USB. https://answers.microsoft.com/en-us/insider/forum/all/how-to-perform-a-clean-install-or-reinstall-of/aef0ae63-2117-41ee-a8ea-4a3181625b08
Note:
If you don't want to clean install or reset the system, let me know so we can try to fix the CBS corruption manually.
I cant do that kind of reset because it asks for my password and I don't know it. I set it up to bypass login.
CBS corruption manually please
Deleted
2025-03-15T02:54:29+00:00 I cant do that kind of reset because it asks for my password and I don't know it. I set it up to bypass login.
You can reset the MSA password using the steps listed here.
Change or Reset Your Password in Windows - Microsoft Support:
(You may also create a second admin account, which can be a local account. Use it to log in to WinRE.)
(or)
Download cbsdiag.zip. Extract cbsdiag.bat and save it to desktop. Right-click cbsdiag.bat, click Properties, select Unblock, and click OK..
Right-click cbsdiag.bat, and choose "Run as administrator".
(The batch file contains plain text code. You can read its contents using Notepad before running it. It collects the CBS registry key and servicing related information to fix the corruption.)
(How-To: Share OneDrive files and folders - Microsoft Support)
OneDrive sharing options - screenshot: https://imgur.com/a/vZyxpY9
Standard Disclaimer: There is a link to a non-Microsoft website. The page appears to provide accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as PUPs (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
2025-03-15T13:57:23+00:00 I cant do that kind of reset because it asks for my password and I don't know it. I set it up to bypass login.
(or)
Ok I found the password sorry for the trouble.
Now I did shift-key and reboot to get to repair. So it's resetting now fingers crossed. :)
Fail "there was a problem resetting this computer " :(
