You're welcome 👍
OS Build 19045.4957 Quality Updates (50) 2025-02 Cumulative Update for Windows 10 Version 22H2 for x64-based Systems (KB5051974) (2) Failed
OS Build 19045.4957
Failed to install on Mon-Mar-03-2025 - 0x80070002
Either KB5050593 or KB5050188 currupted my ability to edit txt and bat files.
2025-01 Cumulative Update Preview for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050593) Successfully installed on Mon-Mar-03-2025
One of these currupted my edit txt and bat command
2025-01 Cumulative Update for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050188)
I tried all the work arounds and that didn't work.
61 additional answers
2025-03-14T15:59:08+00:00 You seem to have tried the repair installation, which is not the same as Reset.
- To reset Window 10 keeping files, open Settings > Update & Security > Recovery, click “Get started” for “Reset this PC,” choose “Keep my files,” select “cloud”, click “Next,” and “Reset.”
Your apps and settings will be gone during the reset. If you choose "keep my files", your personal files will be intact.
https://imgur.com/81s8Zys Fail :(
2025-03-14T16:06:37+00:00 Please try from WinRE, The 3rd option in this link. https://pureinfotech.com/reset-pc-keeping-files-windows-10/#reset_windows10_winre
If that doesn't work, you may backup the data to external drive and clean install Windows 10 using USB. https://answers.microsoft.com/en-us/insider/forum/all/how-to-perform-a-clean-install-or-reinstall-of/aef0ae63-2117-41ee-a8ea-4a3181625b08
Note:
If you don't want to clean install or reset the system, let me know so we can try to fix the CBS corruption manually.
Deleted
2025-03-14T16:13:56+00:00 Please try from WinRE, The 3rd option in this link. https://pureinfotech.com/reset-pc-keeping-files-windows-10/#reset_windows10_winre
Note:
Ok thx I'll try the first one but I don't want to do a clean install.
Reply Edit
