You're welcome 👍
OS Build 19045.4957 Quality Updates (50) 2025-02 Cumulative Update for Windows 10 Version 22H2 for x64-based Systems (KB5051974) (2) Failed
OS Build 19045.4957
Failed to install on Mon-Mar-03-2025 - 0x80070002
Either KB5050593 or KB5050188 currupted my ability to edit txt and bat files.
2025-01 Cumulative Update Preview for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050593) Successfully installed on Mon-Mar-03-2025
One of these currupted my edit txt and bat command
2025-01 Cumulative Update for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050188)
I tried all the work arounds and that didn't work.
61 additional answers
2025-03-17T15:51:36+00:00 If you're not sure, redo the steps and note the output. If it imports correctly, run the setup.
Ok it reset looks good. Now getting updates see what happens.
2025-03-17T15:58:33+00:00 If you're not sure, redo the steps and note the output. If it imports correctly, run the setup.
You meant repair installation, right? Reset is different.
2025-03-17T16:12:10+00:00 If you're not sure, redo the steps and note the output. If it imports correctly, run the setup.
Yes as instructed. It gave me this https://imgur.com/A8tNpBj
All updates installed except KB5053606 it's trying to install that now see what happens. :)
Deleted
