You're welcome 👍
OS Build 19045.4957 Quality Updates (50) 2025-02 Cumulative Update for Windows 10 Version 22H2 for x64-based Systems (KB5051974) (2) Failed
OS Build 19045.4957
Failed to install on Mon-Mar-03-2025 - 0x80070002
Either KB5050593 or KB5050188 currupted my ability to edit txt and bat files.
2025-01 Cumulative Update Preview for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050593) Successfully installed on Mon-Mar-03-2025
One of these currupted my edit txt and bat command
2025-01 Cumulative Update for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050188)
I tried all the work arounds and that didn't work.
61 additional answers
2025-03-16T02:21:33+00:00 Thanks. Please do the following.
Run "dism /online /cleanup-image /scanhealth". After it completes, attach "c:\windows\logs\cbs\cbs.log" on OneDrive.
Ok here it is. https://1drv.ms/u/s!AuRlXV5noNjZgVxSLw-aOlTTDljF?e=dpZhu6
- Download SFCFix.exe (by niemiro of Sysnative forums) and save this to your Desktop.
https://www.sysnative.com/forums/downloads/sfcfix/
- Download the file, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
- On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. [See illustration image: https://imgur.com/a/7i4Y8g8]
- When you see the prompt "Will you allow SFCFix to communicate with Sysnative servers?", type "n" for no. Press Enter to continue.
- SFCFix will now process the script. It will take some time to complete. Upload the output file SFCFix.txt to your OneDrive.
- Restart Windows and attempt to install updates.
(Will post the remaining fix after seeing the above log.)
2025-03-16T18:54:21+00:00 Thanks. Please do the following.
ok here is the link. https://1drv.ms/t/s!AuRlXV5noNjZgV6ZDbdhK7HyFQoo?e=OKORWv
2025-03-17T03:07:23+00:00 Please download Acelogix Regbak and backup the registry.
Then, do the following:
- Download cbsfix.reg and save it to a folder on the C drive -- e.g., C:\Fixes
- Download AdvancedRun (64-bit) from Nirsoft and run it.
- Using AdvancedRun, launch c:\windows\regedit.exe as TrustedInstaller (see Screenshot)
- In the Regedit window, click File, and click Import...
- Dismiss the "Location is not available" message box by clicking OK.
- In the "Import Registry File" window, in the "File name" text box, type C:\Fixes\cbsfix.reg and press Enter.
- After the import is successful, exit Regedit.
2025-03-17T13:07:02+00:00 Please download Acelogix Regbak and backup the registry.
Ok done.
But yesterday I was able to edit files but today before I did this I lost it. Should I do system restore and try again?
It seems to be KB5053606 update even though it fails to install that's causing me to lose edit control.
