You're welcome 👍
OS Build 19045.4957 Quality Updates (50) 2025-02 Cumulative Update for Windows 10 Version 22H2 for x64-based Systems (KB5051974) (2) Failed
OS Build 19045.4957
Failed to install on Mon-Mar-03-2025 - 0x80070002
Either KB5050593 or KB5050188 currupted my ability to edit txt and bat files.
2025-01 Cumulative Update Preview for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050593) Successfully installed on Mon-Mar-03-2025
One of these currupted my edit txt and bat command
2025-01 Cumulative Update for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 for x64 (KB5050188)
I tried all the work arounds and that didn't work.
61 additional answers
2025-03-11T21:27:29+00:00 Hello ,
I’m here to help you in resolving your issue
you can try installing manually using below link
https://www.catalog.update.microsoft.com/Search...
If you can’t edit TXT and BAT files after KB5050593 or KB5050188, try these:
Reset File Associations:
1: Go to Settings > Apps > Default Apps.
2: Scroll down and click Reset to Microsoft recommended defaults.
3: Now, manually set:
TXT files > Notepad
BAT files > Notepad or CMD
4: Try editing a text or batch file again.
After trying above steps, please reach out to me if you have any doubts or issues
Help others by sharing your experience! Click “Yes” if this solution worked for you or “No” if it didn’t.
