I have this weird problem where browsing applications force close themselves? I have found a mini work around and that is to go and rename the exe file to something like "Chrome2.exe" or "Brave2.exe"
2025-06-12T07:32:02+00:00
What is going on how do i fix it? Everytime i open these apps it just closes and i dont understand what to do? I have reset my computer, i have reinstalled all of these apps multiple times. Im very confused and would like some help, this only started happening recently so i dont know what was different between now and then.
The only browser that works fine on the laptop as of now is edge.
Please help!!!
Windows for home | Windows 11 | Internet and connectivity
2025-06-15T05:45:56+00:00
Hi ,
Well, generally the block can be applied to everyone in the family in the configuration, which I think your parent has to check if in the Microsoft family system you are considered a minor, perhaps due to a date error.
https://answers.microsoft.com/pt-br/windows/for...
He may also try to remove you or re-add you, you can correct the dates.
Check if the consent system is active.
1- To remove consent from a family member's account,
2- Visit family.microsoft.com and sign in to your Microsoft account.
3- Scroll down and select Manage my child's profile information.
4- Find your family member and select Remove consent for this child's account.
Unfortunately, you were right to distrust the Microsoft Family system because there was nothing preventing you from doing so other than being in the family system.
The last option is to contact your father's Microsoft support and inform them of the situation to see if there is any error.
This is not a Windows problem, but rather a problem with the Microsoft family system.
https://support.microsoft.com/pt-br/contactus
Help the community by letting us know whether the answer was useful or not and by submitting an evaluation.
Independent Advisor - Community
59 additional answers
    2025-06-12T08:20:03+00:00
    Hi ,
    I am Ivan, I will help you with this.
    If you download Autoruns, extract the file and open it, take a screenshot and post it here.
    https://learn.microsoft.com/pt-br/sysinternals/...
    If possible, do an analysis with MSRT and Malwarebytes
    I recommend you do an analysis with Microsoft's MSRT, analyze Windows Defend Offline scan and Malwarebytes.
    MSRT
    https://www.microsoft.com/en-us/download/detail...
    Microsoft Defend:
    https://support.microsoft.com/en-us/windows/hel...
    After the analysis, open the command prompt (admin) and run the commands: sfc /scannow and dism /online /cleanup-image /restorehealth, wait for the process to finish and restart the computer.
    Then perform a clean boot and if you want to uninstall applications that you do not use.
    https://support.microsoft.com/en-us/topic/how-t...
    2025-06-12T08:35:24+00:00
    Hi Ivan, thank you for replying.
    This is the screenshot from autoruns? I opened the one that allowed me to open it. Where do i got from here:)
    2025-06-12T08:39:15+00:00
    Hi ,
    Uncheck the Brave, Google Chrome and Microsoft Edge options.
    If possible, scroll down a little more.
    If possible, access the scheduled tasks tab and take a screenshot and post it here.
    2025-06-12T08:53:03+00:00
    I unchecked them as u said,
