I think I found something. My windows says it cannot connect to the server to verify my windows installation
startup repair couldn't repair your PC
I rebooted the computer and got the auto repair attempt then went into advanced and tried the start up repair. no success.
put in the clone that I had made and just for a little insurance, cloned the clone onto a brand new ssd. used the clone fine all day. booting up the computer gave me the same issue on the 2nd hard drive. put the 3rd clone in and within 24 hours I have 3 separate hard drives that will not boot, all with the same error.
2025-04-24T18:42:00+00:00 -
DaveM121 936.3K Reputation points Independent Advisor2025-04-25T06:56:57+00:00 That would not cause Widows to stop functioning correctly, it would just affect activation, it really is time to consider re-installing Windows since no other troubleshooting steps are working.
2025-04-30T13:14:56+00:00 I have windows working now. On every boot it starts to the recovery screen I hit enter once to choose windows 10, then F8 for boot options, then scroll down to disable driver signature verification and everything works fine.
The driver that is getting flagged is c:\windows\system32\drivers\HDSaver.sys
it is my SSD hard drive driver. I have tried everything to fix that driver but nothing has worked. I tried copying it from another computer, uninstalling it and it keeps popping up. Any ideas?
