startup repair couldn't repair your PC
2025-04-21T15:46:32+00:00
I rebooted the computer and got the auto repair attempt then went into advanced and tried the start up repair. no success.
put in the clone that I had made and just for a little insurance, cloned the clone onto a brand new ssd. used the clone fine all day. booting up the computer gave me the same issue on the 2nd hard drive. put the 3rd clone in and within 24 hours I have 3 separate hard drives that will not boot, all with the same error.
  1. DaveM121 936.1K Reputation points Independent Advisor
    2025-04-21T16:19:22+00:00
    Hi, I am Dave, I will help you with this.
    It is very strange for 3 versions of Windows to be producing the same start-up errors.
    You indicate you have tried the Startup Repair option in the recovery environment, have you tried any other recovery options, like uninstalling the latest Windows update, System Restore and accessing Safe Mode?
    2025-04-21T17:18:17+00:00
    On the first drive, i tried restore to a previous day and uninstall last update. i tried the fix boot and got access denied
  3. DaveM121 936.1K Reputation points Independent Advisor
    2025-04-21T17:24:55+00:00
    Because this has happened to 3 Windows installations, have you checked for any BIOS update that may be available and not yet installed.
    2025-04-21T17:43:03+00:00
    I just was able to get one of the drives to boot. Let me know if there are any scans or info I can collect that may lead to fixing the other two or at least getting this one golden and cloning to the others.
  5. DaveM121 936.1K Reputation points Independent Advisor
    2025-04-21T17:49:27+00:00
    If you have managed to boot into one of the Windows installations, the best option would be to perform an in-place repair with the Windows 10 ISO to stabilise that Windows installation.
    Please follow the steps, this is then not like re-installing Windows, it is just like an update and your personal files, settings and installed software will not be affected.
    Click this link:
    https://www.microsoft.com/software-download/win...
    to download the Media Creation Tool (Click on Download Tool Now), with that you can download the latest Windows 10 ISO (Select Create Installation Media for Another PC), then choose ISO, not USB
    When the ISO file completes downloading
    Disconnect from the Internet
    Disconnect all external devices with the exception of a mouse or keyboard.
    Temporarily disable any 3rd party Anti-virus you may have installed
    Then, in Windows File Explorer, double click the ISO and then run Setup.exe and select the Install option.
    Very Important - ensure you select the option to keep your files and apps.
