Win10, Right click on pinned programs in Start Menu no longer have file list
2025-04-07T16:20:42+00:00
I'm pretty sure this occured after the latest update (which is actually four updates). I removed all four updates and the right click latest file function is still not there.
The update was: March 25, 2025-KB5055063 Cumulative Update for .NET Framework 3.5, 4.8 and 4.8.1 for Windows 10 Version 22H2 - Microsoft Support
The first update removed as listed is KB5054978. I lost track of the other 3 updates installed at the same time.
THIS IS THE EXACT MAIN REASON I WOULDN'T GO TO WINDOWS 11!!!! I'll be glad when there are no more win10 updates!
How do I get this right click function back? Below is the menu I get when I now right click on a pinned start menu, program:
  1. Siva Shankar 11,020 Reputation points
    2025-04-07T17:54:15+00:00
    Hello ,
    I’m here to help you in resolving your issue
    1. Re-enable Jump Lists in Settings
    Sometimes the setting gets silently disabled:
    a. Go to Settings > Personalization > Start
    b. Turn ON both:
    “Show recently opened items in Jump Lists on Start or the taskbar”
    “Show recently added apps”
    c. Then reboot.
    2: Clear and Rebuild Jump List Cache
    Corrupted cache files can cause Jump Lists to disappear.
    a. Press Win + R, type: %AppData%\Microsoft\Windows\Recent\AutomaticDestinations
    b. Delete all files in this folder.
    c. Then go to: %AppData%\Microsoft\Windows\Recent\CustomDestinations
    d. Delete all files here too.
    After trying above steps, please reach out to me if you have any doubts or issues
    2025-04-07T20:07:00+00:00
    #1. These were both set already.
    #2. This happened on two different laptops so it's almost impossible that they both had corruption of the data/cache.
  3. Siva Shankar 11,020 Reputation points
    2025-04-07T21:41:45+00:00
    If it's happening across two different laptops, that strongly points to a systemic issue introduced by a recent update, rather than local corruption or misconfiguration.
    Please report this issue to Microsoft using Feedback Hub application(win+F)
    2025-04-09T17:02:56+00:00
    Thank you for your reply. I have the same issue. I have tried both options: re 1: these settings were already set, re 2: I have deleted the files, but the problem remains. Please help. It is very inconvenient this feature is not working anymore! Thank you
    2025-04-10T14:57:20+00:00
    I did this: "Please report this issue to Microsoft using Feedback Hub application(win+F)"
    I haven't heard anything back at all. I still have this problem.
    You should provide feedback to help the cause.
    I'm guessing MS is making it like Win11 so that you switch over.
