i have found it here is the newest minidump file
how can i fix my bsod problem i keep getting the kernel mode heap corruption error code
here is the mini dump file if anyone can help me figure out what my problem is
StartFragment
8: kd> !analyze -v
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
KERNEL_MODE_HEAP_CORRUPTION (13a)
The kernel mode heap manager has detected corruption in a heap.
Arguments:
Arg1: 0000000000000017, Type of corruption detected
Arg2: ffffb78449100380, Address of the heap that reported the corruption
Arg3: ffffb7845968dec0, Address at which the corruption was detected
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 1531
Key : Analysis.Elapsed.mSec
Value: 4621
Key : Analysis.IO.Other.Mb
Value: 0
Key : Analysis.IO.Read.Mb
Value: 1
Key : Analysis.IO.Write.Mb
Value: 0
Key : Analysis.Init.CPU.mSec
Value: 359
Key : Analysis.Init.Elapsed.mSec
Value: 12822
Key : Analysis.Memory.CommitPeak.Mb
Value: 101
Key : Analysis.Version.DbgEng
Value: 10.0.27829.1001
Key : Analysis.Version.Description
Value: 10.2503.24.01 amd64fre
Key : Analysis.Version.Ext
Value: 1.2503.24.1
Key : Bugcheck.Code.LegacyAPI
Value: 0x13a
Key : Bugcheck.Code.TargetModel
Value: 0x13a
Key : Dump.Attributes.AsUlong
Value: 0x21008
Key : Dump.Attributes.DiagDataWrittenToHeader
Value: 1
Key : Dump.Attributes.ErrorCode
Value: 0x0
Key : Dump.Attributes.KernelGeneratedTriageDump
Value: 1
Key : Dump.Attributes.LastLine
Value: Dump completed successfully.
Key : Dump.Attributes.ProgressPercentage
Value: 0
Key : Failure.Bucket
Value: 0x13a_17_nt!RtlpHeapHandleError
Key : Failure.Hash
Value: {b1500314-0083-90bd-d812-716f3060523d}
BUGCHECK_CODE: 13a
BUGCHECK_P1: 17
BUGCHECK_P2: ffffb78449100380
BUGCHECK_P3: ffffb7845968dec0
BUGCHECK_P4: 0
FILE_IN_CAB: 060525-7484-01.dmp
DUMP_FILE_ATTRIBUTES: 0x21008
Kernel Generated Triage Dump
FAULTING_THREAD: ffffb78450f46080
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
ffff8083`b6c92408 fffff807`aa5ad528 : 00000000`0000013a 00000000`00000017 ffffb784`49100380 ffffb784`5968dec0 : nt!KeBugCheckEx
ffff8083`b6c92410 fffff807`aa5ad588 : 00000000`00000017 00000000`000002ef ffffb784`49100380 00000000`00000000 : nt!RtlpHeapHandleError+0x40
ffff8083`b6c92450 fffff807`aa2389e1 : ffffb784`59688000 ffffb784`49100380 00000000`00000000 00000000`00000000 : nt!RtlpHpHeapHandleError+0x58
ffff8083`b6c92480 fffff807`aa46c735 : fffff807`00000001 00000000`00000001 00000000`00000000 00000020`00000000 : nt!RtlpLogHeapFailure+0x45
ffff8083`b6c924b0 fffff807`aa328bf5 : ffffb784`59688000 00000000`000002c8 ffffb784`49100380 fffff807`aa2e69dd : nt!RtlpHpLfhReportError+0x21
ffff8083`b6c924f0 fffff807`aa328e88 : ffffb784`59688000 00000000`00000020 00000000`001002f5 000ffffb`78459688 : nt!RtlpHpLfhSubsegmentDelayFreeListProcess+0x255
ffff8083`b6c92570 fffff807`aa433b42 : 00000000`00000007 00000000`001002f5 ffffb784`49100380 ffffb784`49102a80 : nt!RtlpHpLfhOwnerRunMaintenance+0x174
ffff8083`b6c925d0 fffff807`aa433c1f : 00000000`00000000 fffff807`aa3a2be0 ffffb784`491002c0 ffff8083`b6c9278c : nt!RtlpHpLfhOwnerCompact+0xc2
ffff8083`b6c92750 fffff807`aa4338ef : ffffb784`49100000 fffff807`aa433ca6 00010000`00000000 00000000`00000000 : nt!RtlpHpLfhOwnerCompact+0x19f
ffff8083`b6c928d0 fffff807`aa433825 : ffffb784`49100000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!RtlpHpLfhContextCompact+0xa3
ffff8083`b6c92910 fffff807`aa4337c3 : 00000000`00000001 00000000`00000000 00000000`00000001 ffffb784`50f460c0 : nt!RtlpHpHeapCompact+0x21
ffff8083`b6c92940 fffff807`aa473655 : 00000000`00000001 00000000`00000001 00000000`00000000 fffff807`aa30a4d8 : nt!ExpHpCompactHeapCallback+0x23
ffff8083`b6c92970 fffff807`aa4735b5 : 00000000`00000001 ffff8083`b6c92b00 ffffb784`49823ae0 ffffb784`49823ae0 : nt!ExpHpEnumerateHeaps+0x71
ffff8083`b6c929d0 fffff807`aa309e32 : ffffb784`50f46080 ffffb784`49823a00 00000000`00000000 ffffb784`00000000 : nt!ExpHpCompactionRoutine+0x15
ffff8083`b6c92a00 fffff807`aa45904a : ffffb784`50f46080 ffffb784`50f46080 fffff807`aa309c80 ffffb784`49823ae0 : nt!ExpWorkerThread+0x1b2
ffff8083`b6c92bb0 fffff807`aa6741c4 : ffffa581`7a781180 ffffb784`50f46080 fffff807`aa458ff0 00000000`00030d40 : nt!PspSystemThreadStartup+0x5a
ffff8083`b6c92c00 00000000`00000000 : ffff8083`b6c93000 ffff8083`b6c8c000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME: nt!RtlpHeapHandleError+40
MODULE_NAME: nt
IMAGE_NAME: ntkrnlmp.exe
IMAGE_VERSION: 10.0.26100.1742
STACK_COMMAND: .process /r /p 0xffffb784496a6040; .thread 0xffffb78450f46080 ; kb
BUCKET_ID_FUNC_OFFSET: 40
FAILURE_BUCKET_ID: 0x13a_17_nt!RtlpHeapHandleError
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {b1500314-0083-90bd-d812-716f3060523d}
Followup: MachineOwner
EndFragment
2025-06-07T13:34:43+00:00 -
2025-06-07T16:03:45+00:00 Sorry I was offline.
Thanks for the file, it indicates that the cause of the BSOD is "rtwlane601.sys" which is related to Realtek network driver.
Disable Driver Verifier, go to the manufacturer's website, search for your system/motherboard model and download the recommended driver for Realtek Network.
2025-06-07T16:10:09+00:00 Okay thank you so much I shall go and download the wifi drivers from the website again and see if that fixes my problem if I get this fixed would it get rid of my bsod?
2025-06-07T16:12:00+00:00 The file indicates that this is the cause of the last BSOD. If the other BSODs are the same cause, this should solve the problem.
2025-06-07T16:18:25+00:00 The weirdest part of it though is that I’ve reinstalled windows multiple times and I’ve reinstalled all my drivers multiple times but the kernel mode heap corruption keeps coming back to me
