You have been incredibly amazing to work with too. Glad that everything is working now. If all is resolved, feel free to mark the answer for this thread and feel free to choose a rating and have a great day Andrew!
All the best!
So I turned my PC on in the morning after putting it into sleep mode, I then proceeded to restart it because it wasn't opening my programs. After it restarted it sent me to the recovery page and it doesn't let me get out of it. I tried using my spare Windows 10 backup and that doesn't work either. Please help
All the best!
Thanks for clarifying, Andrew; that makes a lot more sense now. If possible, use another working computer to run the Media Creation Tool and create your bootable USB. If that still fails on a different computer, try to use a different USB.
If you don’t have another USB, you might consider borrowing one or purchasing a reliable 8–16GB flash drive. It’ll be useful long-term for backups or emergencies like this in the future.
Let me know how it goes. I’ll stay with you through the rest of the recovery steps.
Great! Now you are on the right setup page. Make sure to choose and highlight Drive 0 Partition 2 (223 GB) and click Next.
Let me know what happens after clicking Next. Just avoid formatting the drive.
Follow on-screen instructions if that allows you to move forward.
On every single drive I click on it says Windows cant be installed
