Why does my PC keep booting into the bluescreen and not let me leave
2025-06-26T22:08:47+00:00
So I turned my PC on in the morning after putting it into sleep mode, I then proceeded to restart it because it wasn't opening my programs. After it restarted it sent me to the recovery page and it doesn't let me get out of it. I tried using my spare Windows 10 backup and that doesn't work either. Please help
2025-07-01T04:01:24+00:00
You have been incredibly amazing to work with too. Glad that everything is working now. If all is resolved, feel free to mark the answer for this thread and feel free to choose a rating and have a great day Andrew!
All the best!
48 additional answers
    2025-06-28T05:16:59+00:00
    Thanks, Andrew that’s super helpful. This confirms you are on the correct drive (E:) and Windows was previously installed here
    Now the goal is to free up enough space (at least 1–2 GB) so the system can boot or repair properly. Here's the next exact set of things to do.
    ** In Command Prompt:
    rd /s /q E:$Windows.~BT
    rd /s /q E:\Windows\SoftwareDistribution\Download
    rd /s /q E:\Windows\Temp
    These remove upgrade leftovers and temporary installer files.
    **: Disable Hibernate (delete hiberfil.sys)
    If this worked, it’ll free 4–8 GB instantly.
    powercfg /hibernate off
    If you get an error, use this alternative:
    attrib -h -r -s E:\hiberfil.sys
    del E:\hiberfil.sys
    ** Delete Large Logs or Crash Dumps
    Browse to these folders in Notepad > File > Open, make sure to set file type to “All Files (.)”:
    E:\Windows\System32\LogFiles
    E:\Users[YourName]\AppData\Local\Temp
    E:\Windows\LiveKernelReports
    E:\Windows\Memory.dmp (delete this if present, it can be several GB)
    Delete the largest files you find, especially .dmp, .log, and .tmp.
    ***Open Notepad > File > Open > This PC
    Check how much free space is now showing for drive E:
    ***Once you have at least 1 GB free, go to
    Troubleshoot > Advanced Options > Startup Repair
    Choose E: (Windows) if prompted
    ***If Startup Repair still fails:
    Boot from USB
    Click Install Now
    Select Custom: Install Windows only
    Choose E: (your current system drive)
    Do NOT format it
    Windows will move your existing install to a folder called Windows.old
    Your files will be safe in:
    E:\Windows.old\Users[YourName]
    Let me know how much free space do you see after cleanup?
    If any command shows errors?
    If Startup Repair now works or still fails?
    We’re down to the final steps, and I’ll help finish it out with you.
    2025-06-28T05:46:36+00:00
    I tried doing all the commands and it says "Could not find"
    2025-06-28T05:55:23+00:00
    Thanks, Andrew. That tells us those folders or files were either already deleted, or
    never created properly due to the broken update or space issue.
    Try the repair install I have provided instead.
    2025-06-28T06:04:30+00:00
    It still says the system drive is too small
