Hacked or not, Trojan?
I have gotten this exact same "threat" since 24th of april (i figure out how to stop nitifictions) but still, I am not sure what to do I have scaned on my laptop twice with two diffenet antivurs ( malwer byts ( the one in the screen shot) and KVRT) and showe dnothing, my laptop is 100% safe? but this message was poping up, i tryed to delte teh fiel but it is blocked by the microsft coraption. So PLEASE i am DESPERT HELP ME
2025-05-20T01:39:53+00:00 -
Ramesh 181.4K Reputation points Volunteer Moderator2025-05-20T01:41:32+00:00 ok, topaz ai is stll working, I have autheincer app for my out look, and my pssword are saved in keeper extension with complex passwordds.
Ok, I hope that resolves the issue. Let me know.
2025-05-21T22:40:02+00:00 ok, so do i enable mege sync and cmd, form start up or leave thme off?
Ramesh 181.4K Reputation points Volunteer Moderator2025-05-22T05:02:37+00:00 ok, so do i enable mege sync and cmd, form start up or leave thme off?
Yes. But even though the rogue module has been removed and the system is clean, consider removing TopazAI and installing it from the vendor's site if you need it. The one you installed used a self-extracting .rar archive (from an unknown source) that bundled the fake jli.dll. The program loaded this DLL at every startup and tried to establish a connection with a remote host.
The cmd.exe entry in the startup tab can be deleted. To do so, use the Microsoft Autoruns tool and delete the cmd.exe (topazserv.exe) entry in the "Logon" tab.
Autoruns - Sysinternals | Microsoft Learn: https://learn.microsoft.com/en-us/sysinternals/downloads/autoruns
2025-05-23T06:26:37+00:00 ok, one other thing evertime i have something open and click alt tab (right now only google is open) i see something called UNCserver, is that normal, its been here fo rlike foreverr
