Intel Graphics (R) 4000 ISSUE
2025-05-01T13:35:47+00:00
Intel Graphics (R) 4000 is causing my computer to auto-restart when opening a Game or the Internet
My Computer Has 8GB RAM, 2.20GHz, Directx12, and it is a SONY MODEL (E SERIES)
I need a fix, really. I need this so I can use my computer more easily than when it is in safe mode.
for 3 Months.
PLS HELP
DaveM121 936.3K Reputation points Independent Advisor
2025-05-05T10:16:24+00:00
All your device drivers are now installed correctly, if your system is still instantly shutting down, then most likely there is a hardware fault, you will need to take your system to a PC Shop to have the hardware tested.
40 additional answers
    2025-05-05T08:02:21+00:00
    THIS ALSO
  2. DaveM121 936.3K Reputation points Independent Advisor
    2025-05-05T08:03:56+00:00
    To resolve the problem please download the Intel Driver and Support Assistant from the Intel website and use that to update your drivers.
    2025-05-05T08:19:57+00:00
    well it did fix one of the unknown drivers
  4. DaveM121 936.3K Reputation points Independent Advisor
    2025-05-05T08:21:51+00:00
    Please provide a screenshot of the Intel Driver and Support Assistant window.
