All your device drivers are now installed correctly, if your system is still instantly shutting down, then most likely there is a hardware fault, you will need to take your system to a PC Shop to have the hardware tested.
Intel Graphics (R) 4000 ISSUE
Intel Graphics (R) 4000 is causing my computer to auto-restart when opening a Game or the Internet
My Computer Has 8GB RAM, 2.20GHz, Directx12, and it is a SONY MODEL (E SERIES)
I need a fix, really. I need this so I can use my computer more easily than when it is in safe mode.
for 3 Months.
PLS HELP
40 additional answers
DaveM121 936.3K Reputation points Independent Advisor2025-05-05T07:44:57+00:00 This is the Sony support website, your model is the SVE15138CGW try searching there for any driers they provide for that model to see if you can find the required chipset drivers.
https://www.sony.com/electronics/support/laptop...
If not, go to the Intel website to download the Intel Driver and Support assistant and use that to update all your Intel drivers.
________________________________________________________
Standard Disclaimer: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
DaveM121 936.3K Reputation points Independent Advisor2025-05-05T07:53:35+00:00 In that case, download the Intel Driver and Support Assistant from the Intel website and use that to install/update all your Intel drivers.
