All your device drivers are now installed correctly, if your system is still instantly shutting down, then most likely there is a hardware fault, you will need to take your system to a PC Shop to have the hardware tested.
Intel Graphics (R) 4000 ISSUE
Intel Graphics (R) 4000 is causing my computer to auto-restart when opening a Game or the Internet
My Computer Has 8GB RAM, 2.20GHz, Directx12, and it is a SONY MODEL (E SERIES)
I need a fix, really. I need this so I can use my computer more easily than when it is in safe mode.
for 3 Months.
PLS HELP
40 additional answers
2025-05-02T12:07:34+00:00 Ya I did, but no use.
DaveM121 936.3K Reputation points Independent Advisor2025-05-02T12:16:07+00:00 In that case, go to the Intel website, then from there, download the Intel Driver and Support Assistant, then use that utility to update all your Intel drivers.
2025-05-04T08:14:12+00:00 I checked and it did not solve my problem
DaveM121 936.3K Reputation points Independent Advisor2025-05-04T08:18:33+00:00 1
Open Device Manager, then expand the Display Adapters section, please provide a screenshot of that window.
2
Click your Start Button, then just type winver and press Enter, please provide screenshot of the resulting dialog box.
