Problem with updating to 23H2
2025-04-12T00:03:58+00:00
Hello! I have a problem that I'm trying to fix for a year and its regarding Windows 11, version 23H2 update. When I download and install it from the WIndows Update everything is fine but when it starts insalling this is where the problem begins. It goes to black screen and the text saying "Update is underway. Don't turn your pc off. Your pc may restart a few times". This is a normal screen appearing everytime you download, but when it gets to the first restart it changes to another windows with different looking text and it stays for a few seconds then it says "Undoing the changes made to your pc". Then when I go into the Window Update I see an "Install error - 0x80248007" . This has appeared everytime I try to update it. I have tried everything that I could find on the internet, chatgpt, the robot chat responder at microsoft, but nothing works and I need somebody to help me with this problem.
2025-04-14T18:54:45+00:00
No need for that i finally did it. I serached on internet for this error message and came upon another forum that talked about the error and all i had to do was type this command in command pront as Admin:
rundll32.exe pnpclean.dll,RunDLL_PnpClean /DRIVERS /MAXCLEAN
Then I had to turn off my wifi and bluetooth before rerunning the setup. I didn't thought it would work but as soon as my laptop restarted the update was stuck on 0% but it actually started at 12% and I was in shock and it did install and now my laptop is up to date. Thank you for all the work that you put to help me! I'm really greatfull and here is the link to the the forum page that I got the solution from, its the first comment under the post: https://answers.microsoft.com/en-us/windows/forum/all/the-installation-failed-in-the-safeos-phase-with/7f910879-39b1-4459-b3e0-abe84208e4d6
127 additional answers
  1. Ramesh 181.2K Reputation points Volunteer Moderator
    2025-04-12T16:32:06+00:00
    If possible, share the latest log.
    (or)
    If you wish to clean install Windows, please backup the data to an external drive and clean install using the 24H2 USB setup disk.
    See:
    Windows 11 Clean installation: https://www.microsoft.com/en-us/windowsinsider/cleaninstall
    2025-04-12T16:36:23+00:00
    The log doesn't appear to be modified and last time it shows is at 16'o clock. I think the best will be to do a clean installation but I have to buy an external drive, because I don't have one. If you have anymore suggestions or if you want I can make a new log to see what is the problem?
  3. Ramesh 181.2K Reputation points Volunteer Moderator
    2025-04-12T16:37:28+00:00
    The same log gets appended for some reason. If you scroll down, you can see the latest entries.
    2025-04-12T16:46:22+00:00
    The prior images reported that WDV was not in use.
    1. Run Tuneup plus > post a share link
    https://www.tenforums.com/attachments/bsod-crashes-debugging/360139d1645183596-batch-files-use-bsod-debugging-tuneup_plus_log.zip
    Batch files for use in BSOD debugging - Windows 10 Forums
    1. Post a new V2 share link:
    BSOD - Posting Instructions | Windows 11 Forum
    1. Open administrative command prompt and copy and paste:
    dism /online /get-drivers /format:table >c:\drivers.txt
    Post a share link.
    1. Open event viewer > system and application > post share links
    https://www.yourwindowsguide.com/2017/12/how-to-share-event-logs-in-case-of.html
    1. Run: upgrade_failure_info > post a share link
    https://www.tenforums.com/attachments/bsod-crashes-debugging/353454d1638278360-batch-files-use-bsod-debugging-upgrade_failure_info.bat
    Batch files for use in BSOD debugging - Windows 10 Help Forums
    6)Please start WDV with the 3 customized tests in this tutorial:
    Enable and Disable Driver Verifier in Windows 10 | Tutorials
    If there is no immediate BSOD then open administrative command prompt and copy and paste:
    verifier /querysettings
    Post a share link.
    For any BSOD post a new V2 share link into the newest post.
