Problem with updating to 23H2
2025-04-12T00:03:58+00:00
Hello! I have a problem that I'm trying to fix for a year and its regarding Windows 11, version 23H2 update. When I download and install it from the WIndows Update everything is fine but when it starts insalling this is where the problem begins. It goes to black screen and the text saying "Update is underway. Don't turn your pc off. Your pc may restart a few times". This is a normal screen appearing everytime you download, but when it gets to the first restart it changes to another windows with different looking text and it stays for a few seconds then it says "Undoing the changes made to your pc". Then when I go into the Window Update I see an "Install error - 0x80248007" . This has appeared everytime I try to update it. I have tried everything that I could find on the internet, chatgpt, the robot chat responder at microsoft, but nothing works and I need somebody to help me with this problem.
2025-04-14T18:54:45+00:00
No need for that i finally did it. I serached on internet for this error message and came upon another forum that talked about the error and all i had to do was type this command in command pront as Admin:
rundll32.exe pnpclean.dll,RunDLL_PnpClean /DRIVERS /MAXCLEAN
Then I had to turn off my wifi and bluetooth before rerunning the setup. I didn't thought it would work but as soon as my laptop restarted the update was stuck on 0% but it actually started at 12% and I was in shock and it did install and now my laptop is up to date. Thank you for all the work that you put to help me! I'm really greatfull and here is the link to the the forum page that I got the solution from, its the first comment under the post: https://answers.microsoft.com/en-us/windows/forum/all/the-installation-failed-in-the-safeos-phase-with/7f910879-39b1-4459-b3e0-abe84208e4d6
127 additional answers
  1. Ramesh Srinivasan 87,350 Reputation points Independent Advisor
    2025-04-12T03:49:20+00:00
    Hi Alex,
    Please share the latest setupact.log file.
    C:$WINDOWS.~BT\Sources\Panther\setupact.log
    2025-04-12T04:07:06+00:00
    1. Please run the V2 log collector and post a share link into this thread using drop box, or google drive
    BSOD - Posting Instructions - Windows 10 Forums
    BSOD - Posting Instructions | Windows 11 Forum (elevenforum.com)
    https://www.tenforums.com/tutorials/3813-language-add-remove-change-windows-10-a.html
    https://www.tenforums.com/tutorials/136792-change-display-language-windows-10-a.html#option1
    1. Run Tuneup plus > post a share link
    https://www.tenforums.com/attachmen...-files-use-bsod-debugging-tuneup_plus_log.bat
    Batch files for use in BSOD debugging - Page 2 - Windows 10 Forums
    Batch files for use in BSOD debugging - Windows 10 Forums
    1. Run: upgrade_failure_info > post a share link
    https://www.tenforums.com/attachments/bsod-crashes-debugging/353454d1638278360-batch-files-use-bsod-debugging-upgrade_failure_info.bat
    Batch files for use in BSOD debugging - Windows 10 Help Forums
    1. Open administrative command prompt and copy and paste:
    schtasks.exe /Run /TN "\Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser"
    reg query "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\TargetVersionUpgradeExperienceIndicators" /s
    Post a share link.
    1. Search for:
    C:\Windows\Logs\CBS\CBS.log
    C:\Windows\Logs\CBS\CbsPersist
    Post share links.
    For share links please use drop box or google drive.
    Make sure that links are available without sign in.
    https://support.google.com/drive/answer/2424384?hl=en&co=GENIE.Platform%3DDesktop
    2025-04-12T04:12:10+00:00
    Hi so i tried it a second time and it did install till the end then It restarted and started doing the update it restarted then the "Undoing changes made to your pc" message showed up and after I logged in this message appeared:
  4. Ramesh Srinivasan 87,350 Reputation points Independent Advisor
    2025-04-12T04:23:25+00:00
    Hi Alex,
    Ok.
