After replacing hard drive, I can't get my system back to Windows 10
2025-06-04T03:40:44+00:00
I am dealing with an older HP Pavillion Elite HPE-112y here, refurbing it. I have a legit copy of Windows 7 premium home addition, and had upgraded to Windows 10, during the offer for free upgrade, several years ago. I replaced the hard drive; and now, have managed to get back the Windows update service via 4 manual updates to the Windows updater, and couple settings changed TS.1 AND 2; and installing my win7premium home recovery disks, to new drive. I also managed to install service pack 1 manual install. So, I seem to be operating now, on the new drive (Seagate 2GIG compute (do to MBR formatting issue); with Windows 7 recovered from my discs previously made, and service pack 1 for Windows 7 update, working. A new 2 gig barracuda(compute). Only other changes, are the clock battery, and new RAM; both working well. I scratched and clawed my way this far; but am now stuck in rabbit hole feedback loops. The instructions I am getting, for exactly what I have, never work; and usually relate to something else in some place. Rufus says it only supports 8 and above. The Windows Software install tool, will install, but will not run. I have even dared the registry; and given permission for Operating system change. Turned on the TS.1 and 2 deal.............gone in and put the version to Win 7; for the Windows software installer tool to run in a different mode; that tool Will not run on my machine. I don't do this often, and always a challenge, but I am against a wall it seems.
I just tried sorting out the process, to digital link my computer; to the Microsoft servers, but that again goes down the paradoxical rabbit hole; and starts describing features and screens, in Windows 10 already. I don't have those features, because I am stuck in Windows 7 service pack 1 la la land. I even attempted to download an image; which gets a bit complicated for me; only done it one other time. That seemed stuck in downloads, too big for a dvd BURN, and of course did not want to leave the host machine, to protect copyrite. That would get into reloading everything from scratch; and not sure I can pull that off; have not worked with image copies much. Could not find the download to USB option for an instalable copy of windows, if that would work. What I need, is a way to upgrade or update the "current" windows7SP1 environment operating now on my "new drive", to Windows Ten. The version of Windows ten working on failing drive, is digital linked to my account and valid; but it may be a bit corrupted, and part of the big refurb goal, was to start with a fresh operating system. In fact, not impossible WIN10 on failing drive, is an operating system corruption issue; but needed to refurb the whole computer anyway. It seems maybe, it has something to do with getting my machine linked to the Windows server? Maybe not seeing me as a legit copy of windows verified? But, I can't do much with that; through Windows 7SP1. All the forum advice, relates to screens in WIN ten or maybe 8. If I was there, I would not be having such a problem; and need to link, and all that to start. Edge and Internet explorer, are older versions; but I can get on line with Edge legacy I think it is, here now. Edge keeps reverting back to a version of Vista, when I set it for win7. But it is working for me here now; on some level.
It is almost like; someone made the operating system obsolete with anything prior to 2008, and doesn't want to tell me........or I am complicating something very simple, but seems very hard; to get my system back, after a simple hard drive replacement. I have nothing on the new drive, clean boot drive install. Not working around files and apps on the new drive; total rebuild of my system, after I get WIN10 back up. I already had to ditch my new 4gig drive, do to the formatting issue relating to MBR/GPT, and have a couple hundred in this now. It is still in pretty good shape really; boards cleaned quite well, and still a very functional machine. Not a boat anchor to me; even if it is old. 16gigg of DDR3 ram SATA3 3.0GIG per second original drive. It is an AMD machine Phenom 2 X4-925 (D) 2.8 GIG PROCESSOR with AMD chipset 785g, and legacy bios. However, it worked well with Windows10 upgrade installed, for several years. So, the mechanics work fine, with Windows 10; but perhaps the AMD infrastructure, is causing some kind of proprietary conflict with the Windows software installer tool, or with seeing me as a certified digital software owner? Any ideas. I could do a fresh install of Win10; with right instructions; but was a long way getting back to Win7sp1 with updater working. After more than 200 updates installed; don't want to go through that again; if there is any way to update WIN7SP1, to WIN10. I even thought about the manual upgrade to a version of WIN8, then maybe to ten; but that seems to indicate, it won't upgrade further. Reinstall windows 10 after hard drive failure and replacement - Microsoft Community Tried this, it won't "run". Error message, related to incompatibility, with the software installer; but the installer says it can do WIN7 upgrades to ten. If I could get this installer to run; It might be smooth sailing from there. Why won't it run? Has to be some kind of license recognition issue, or something specific to my computer. Also have run it in safe mode, no difference. Shut down firewall and not any spyware detection running in WIN7, scanner only it seems; and even shut down most process and applications that might conflict. Yes ran it as administrator. Yes, reinstalled it several times from microsoft, and a couple other places and links, seeming safe. Remember here; I am trying to upgrade RIGHT NOW; from A Win7sp1 platform; so all the advice relating to getting WIN10 back, using more modern software, or examples, or screens from WIN10; has a digital wall right now. Legacy edge is my browser working from a download, and it does not like the primitive environment much either;. sp1 is better than it was with updates; but still in caveman era of screens and capabilities here right now.....till I can get upgraded or installed. There has to be a better way, the solutions sound so simple in support; that it can be done easy; but I am not finding that at all. Perhaps I am complicating it. Can't I get a reinstall, since I am licensed; either a download from a server of win10 or upgrade, or even to my USB. I really want to update to 10 from 7sp1 at this point; but open for ideas likely to work. Oh, I also tried various drivers relating to my machine; fist tried Intell that obviously did not work with my AMD chipset something like an f6 driver update, installed through the repair disk; perhaps not doing it correct; but wouldn't touch it with drivers, from AMD sight either. I originally had things set up, to only update WINDOWS, so perhaps an update to a driver or such; could solve the issue, for Windows software installer not running, do to compatibility issue. Sorry for the discombobulated delivery and bad sentence structure here. Been a long rough week.
Windows for home | Windows 10 | Licensing and activation
2025-06-04T04:43:55+00:00
Hello Edward! Thank you for reaching out. I am Tin, an independent advisor, and glad to assist you today with this issue. Since you already have a digital license tied to this machine’s motherboard, you do not need to upgrade from within Windows 7. A clean install of Windows 10 will recognize your hardware and activate automatically. Here is some steps to do a clean install of Windows 10.
*Create a Windows 10 USB installer, on another PC, download installer from https://www.microsoft.com/software-download/win..., click “Download Tool Now” to get the Media Creation Tool. Run the tool, accept terms, and choose “Create installation media for another PC”. Choose USB flash drive when asked where to save. Let it create the bootable USB (this may take 10–20 mins).
*Install Windows 10 on your HP Pavilion, insert the USB drive. Boot into BIOS (usually F10, Esc, or Del on HP machines). Set the boot device to your USB drive. Save and restart.
*Do a clean install, at the install screen, select language and time then click Next. Click Install Now. When prompted for a license key, click “I don’t have a product key” (your license is digital and will activate later). Choose Windows 10 Home (to match your Win7 Home Premium). Select Custom, Install Windows only. Delete all partitions on the drive (make sure you’ve backed up anything important). Select the Unallocated space and click Next. Windows will install cleanly.
*Automatic activation, after the install, connect to the internet. Go to Settings then Update & Security then Activation. Windows 10 should automatically activate using your previously linked digital license.
2025-06-04T08:52:20+00:00
You may be out of luck with activation.
Although you upgraded to Windows 10 when the free offer was available Microsoft have blocked Windows 7 or 8 product keys from activating Windows 10 in 2023.
So with all the effort you may find Windows 10 will not activate.
61 additional answers
    2025-06-08T20:27:32+00:00
    The file fido.ps1 is here. Click the "Download raw file" button.
    It is a Powershell script to run on your PC.
    Start a Powershell session with admin rights
    Enable scripting (if necessary):
    Set-ExecutionPolicy -ExecutionPolicy Bypass -Scope CurrentUser
    Type Y to accept change
    Run the Fido script using its full path to wherever you saved the download:
    e.g. C:\Users\xxxxx\Downloads\Fido.ps1
    The Powershell session will close and a small Fido GUI will open:
    Select the version of Windows you want.
    You can then use the ISO with method 2 mentioned previously. I have lost track of whether you still need to move to a new drive after the upgrade. If not ignore using Macrium.
    2025-06-08T21:07:09+00:00
    I tend to believe you on this, and that the other ways are bootleg?
    I see nothing "bootleg" in your many long posts,
    but you have not indicated whether you purchased a copy of Windows 10 via a retail store, or via the "Microsoft Store", or from some online vendor that supplies, via E-mail, a product-key, and instructions on how to download the Windows 10 installer.
    However; why do you suppose, I can't do this on my current computer, running a legit upgrade of Windows 10. What is different about some other computer; than the one I am using here? I can download the "media creation tool" why might it not "RUN" ?
    What error-message do you get when you try to run the tool?
    In the past, you posted an image, and that image had a clickable link, to "see more details". I asked you to post those details, but you have not yet done so.
    I think, if I could just get the tool to work, and download the ISO; I might be good here.
    True.
    The only time I got an ISO on to the USB, and I tried to boot from it; I don't think the ISO was in a form readable.
    When you run the tool, you have 3 options for the download:
    1. save the downloaded file as an ISO;
    2. "burn" the ISO to one dual-layer DVD disk;
    3. reformat the ISO, and write it to an 8 GB (or larger) empty USB memory-stick.
    Note that it you saved the ISO to your disk-drive, and copied it as an "ordinary" file to the memory-stick, it will NOT be in the correct layout to be a "bootable" device.
    Did you make that mistake?
    I did not do the download of the ISO with the "media creation tool" that time, but some way tricking the severs [servers?] to think it is another operating system; so probably bootleg, and who knows what was on the image, I did download.
    I disagree with your claim of "probably bootleg".
    If is not the usual way of obtaining the ISO directly from Microsoft. A few people have "reverse-engineered" the tool, to see exactly what file is to be downloaded. Any "reverse-engineering" is not allowed, if you click "Accept" when starting to run the Installer.
    But if I could get the media creation tool to run on my machine; I may be home free even.
    You have said that several times before.
    The contributors to this discussion thread have said the same.
    Why do you think the tool won't run on my machine;
    I think that I need that "show details" output that I asked you to supply.
    [My computer] has a nearly updated legit copy of Windows 10, 16 gig of RAM; a good 40 gig of space on the drive left. It has a somewhat never video [newer?] card.
    I have successfully run the Media Creation Tool under Windows 7, with a computer that is very inferior to your computer, to obtain the Windows 10 Installer.
    There is a single update stuck, seems not to want to download right now; but aside that, and some crashes;
    Open Windows Update, and scroll-down to "Update History", and look for any "failed" messages for one of the "KBnnnnn" (Microsoft Knowledge Base) updates. Please post the full text of those 2 or 3 lines.
    this current drive I am on now, will be my retired old drive the minute I get the new drive installed with Windows10; works most of the time.............downloads most stuff just fine, runs most stuff.
    That is your desired outcome.
    Creation tool, should be just copying a large file, to the USB; after some verification.
    Yes. But, the layout of the file(s) written to the memory-stick needs to be in a special format, to make it a "bootable" device.
    Everything else copies and transfers, eventually anyway.
    Do you mean that the file-transfer is slow, or that it fails to complete when reading from your disk-drive, or when writing to some other media/disk-drive? Maybe, your computer does have some problem that is getting in the way.
    I just spent about 2 months; getting everything backed manual from this drive. Moving boatloads of files to USB's, and passports.
    OK, but that is not related to this discussion thread.
    Did you have any difficulties when copying your collection of files/folders ?
    This is a program, and a big one; but still just downloading bits, it seems.
    As I previously posted, I had no problems running the tool on a "vintage" Windows 7 system. Also, I have had no problems running the tool on both Windows 10 and Windows 11 computers.
    I download smaller programs fine, and various other content.
    It wasn't perfect, some glitches and crashes;
    Please supply more details about those "glitches and crashes".
    Maybe, there is something wrong with your computer.
    Previously, I have suggested that get a friend to download and run the tool on their Windows-based computer, and loaning your USB memory-stick to the friend, so that the tool can correctly write onto your memory-stick.
    but I have downloaded and transferred; boatloads of data last couple month, over a terabyte.
    That is good. But, that information does not give any useful information to solve your issue.
    2025-06-08T21:24:37+00:00
    I am posting what I have got so far. Powershell is a bit above my tech pedigree; however, I am trainable often; am willing to give it a try. So here is what I have done. I downloaded the script on to the desktop, with the button that says Raw script. You can see it above the script behind in the open folder. I managed to open powershell, and trying to execute exact commands here. I used the path C:\tiltmonster\desktop\fido; since that is where it it says it is stored in the folder's properties; but everything else, is exact type I think. I managed to give permission, to suspend script writing; which seems a bit dangerous; but no more dangerous, that not having a working operating system. However, step 3; did not give me the screen I suspected, below; to choose the operating system. These instructions are likely, more for someone who know exactly how to use powershell, run scripts, etc; and has used it before. However, if this leads to a solution, and works; I can take some instructions, step by step. I am not sure if the file I downloaded, is in the proper form up there at top on right, so maybe why powershell did not navigate to it; with the command? When I got to step three; I copied the command line shown in the black box below step three, at top. Did not seem to work.
