How do I resolve “stop code: 0xc000007b”? I am not a gamer and not have adequate technical abilities. I submitted a request for help on June 11, 2025
2025-06-13T12:04:47+00:00
    2025-06-13T18:31:55+00:00
    If you cannot click Accept, press the tab key on your keyboard until the accept button is selected, then press Enter to click the button.
    2025-06-13T18:41:29+00:00
    How are you proceeding with this now?
    2025-06-13T18:46:15+00:00
    Where do I install?
    2025-06-13T18:49:28+00:00
    I need assistance Now from a supervisor since you get to go home
    2025-06-13T18:53:02+00:00
    On that window, Disk 0 is the internal drive, Disk 1 at the bottom is your bootable USB, do not touch the partitions on Disk 1.
    Delete each partition on Disk 0 until the whole Disk 0 is marked as Unallocated Space, then select that space and click Next to begin the instalaltion.
