If you have a safe backup of all your files on the cloud to ensure you do not loose your data, then re-install Windows using that bootable USB you have created.
How do I resolve “stop code: 0xc000007b”? I am not a gamer and not have adequate technical abilities. I submitted a request for help on June 11, 2025
2025-06-13T18:10:03+00:00 -
2025-06-13T18:23:25+00:00 I have to log off in a few minutes for the night, it is very late here, honestly, if I am honest, I think your best option it to bring your PC to a PC Shop and get them to re-install Windows for you since none of the avaialble recovery options are resolving the problem for you.
2025-06-13T18:30:35+00:00 Try connecting an external mouse to each avaialble port to see if you can then select that box.
