Thanks Ramesh,
Windows store is installed and photos is also working properly.
Glad to hear that. If the original issue is solved, you may close this thread by marking helpful posts as answers. How to mark Your question as "Answered".
COMPONENTS hive is corrupted, Can someone help in fixing
2025-05-15 21:41:57, Info CBS Failed to load the COMPONENTS hive from 'C:\WINDOWS\System32\config\COMPONENTS' into registry key 'HKLM\COMPONENTS'. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to load component store [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get CSI store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get CSI Store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get inventory [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to load current component state [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to find or add the component family [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS ComponentAnalyzerEvaluateSelfUpdate call failed. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate self update [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate non detect parent update [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate non parent [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS failed to evaluate single applicability [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate applicability [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get applicability on updates [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Error CBS Failed to call external evaluate applicability on package: Package_5_for_KB5033055~31bf3856ad364e35~amd64~~10.0.1.1, Update: 5033055-5_neutral [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate external applicability for package update: 5033055-57_neutral_PACKAGE [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Error CBS Failed to call external evaluate applicability on package: Package_for_KB5033055~31bf3856ad364e35~amd64~~22621.2574.1.1, Update: 5033055-57_neutral_PACKAGE [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to call EvaluateApplicability on internal CBS package. [HRESULT = 0x800703f1]
Thanks Ramesh,
The logs mention many errors that may be related to corruption. If the system is severely corrupted, even In-place Upgrade will not help.
However, the errors may also be related to other factors. Let's investigate further.
Please clarify the following:
Do you have a third-party antivirus installed?
If yes, which one?
Are all of your computer's drivers up to date?
(I suggest checking with the device manufacturer's support area. You can't always find the latest drivers by checking only in Device Manager.)
How much free space do you have on your system drive (C:)?
I await your reply. Click on the "Reply" button below my reply.
Hello David,
Currently, i have 69 GB free on c drive
As well there is no third parth antivirus.
I will have to check for the drivers.
Ok. Check if your drivers are up to date and update any that have an update available.
Then, try the In-place Upgrade again and see if the same error occurs.
If the same error occurs when trying to In-place Upgrade, please share the updated logs for me to analyze.
Tried updating drives and removing all external connected USB's. Still it got failed. Please check logs
