Thanks Ramesh,
Windows store is installed and photos is also working properly.
Glad to hear that. If the original issue is solved, you may close this thread by marking helpful posts as answers. How to mark Your question as "Answered".
COMPONENTS hive is corrupted, Can someone help in fixing
2025-05-15 21:41:57, Info CBS Failed to load the COMPONENTS hive from 'C:\WINDOWS\System32\config\COMPONENTS' into registry key 'HKLM\COMPONENTS'. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to load component store [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get CSI store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get CSI Store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get inventory [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to load current component state [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to find or add the component family [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS ComponentAnalyzerEvaluateSelfUpdate call failed. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate self update [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate non detect parent update [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate non parent [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS failed to evaluate single applicability [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate applicability [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get applicability on updates [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Error CBS Failed to call external evaluate applicability on package: Package_5_for_KB5033055~31bf3856ad364e35~amd64~~10.0.1.1, Update: 5033055-5_neutral [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate external applicability for package update: 5033055-57_neutral_PACKAGE [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Error CBS Failed to call external evaluate applicability on package: Package_for_KB5033055~31bf3856ad364e35~amd64~~22621.2574.1.1, Update: 5033055-57_neutral_PACKAGE [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to call EvaluateApplicability on internal CBS package. [HRESULT = 0x800703f1]
Thanks Ramesh,
Sorry for the delay in reply. I've been offline.
Thanks for the screenshot.
I don't see anything that would prevent you from upgrading to the latest version (24H2).
I suggest you perform an In-place Upgrade to the latest version using a Windows ISO file.
Don't worry. It's a simple procedure, and you have the option to keep files, settings, and apps. Therefore, all your data is kept.
(If you have a third-party antivirus installed, temporarily disable it during the entire procedure.)
Instructions below:
https://www.microsoft.com/en-us/software-downlo...
(The ISO must be in the same language that Windows was originally installed in. Not the current language.)
(After running the ISO, you may need to double-click the "Setup" file to start the procedure.)
(In this step, select "Keep personal files and apps" so that all your data is kept.)
At the end of the procedure, your Windows 11 will be in the latest version (24H2), and some updates will already be installed. But check Windows Update to be sure.
If you need detailed instructions for downloading the ISO, see below.
If you get any errors during or after the procedure, please let me know. Click on the "Reply" button below my reply.
Feel free to ask back any questions.
It has failed again. Can you check the CBS log generated
The in-place Upgrade should have fixed this.
Was the In-place Upgrade completed successfully?
(If you haven't been actively following the procedure, it may have failed in the middle, and you may not even notice.)
Can you give me more details of what you are trying to do?
I await your reply. Click on the "Reply" button below my reply.
