COMPONENTS hive is corrupted, Can someone help in fixing
2025-05-16T16:35:37+00:00
2025-05-15 21:41:57, Info CBS Failed to load the COMPONENTS hive from 'C:\WINDOWS\System32\config\COMPONENTS' into registry key 'HKLM\COMPONENTS'. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to load component store [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get CSI store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get CSI Store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get inventory [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to load current component state [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to find or add the component family [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS ComponentAnalyzerEvaluateSelfUpdate call failed. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate self update [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate non detect parent update [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate non parent [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS failed to evaluate single applicability [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate applicability [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to get applicability on updates [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Error CBS Failed to call external evaluate applicability on package: Package_5_for_KB5033055~31bf3856ad364e35~amd64~~10.0.1.1, Update: 5033055-5_neutral [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to evaluate external applicability for package update: 5033055-57_neutral_PACKAGE [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Error CBS Failed to call external evaluate applicability on package: Package_for_KB5033055~31bf3856ad364e35~amd64~~22621.2574.1.1, Update: 5033055-57_neutral_PACKAGE [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-05-15 21:41:57, Info CBS Failed to call EvaluateApplicability on internal CBS package. [HRESULT = 0x800703f1]
Ramesh 181.6K Reputation points Volunteer Moderator
2025-06-08T14:59:58+00:00
Thanks Ramesh,
Windows store is installed and photos is also working properly.
Glad to hear that. If the original issue is solved, you may close this thread by marking helpful posts as answers. How to mark Your question as "Answered".
69 additional answers
    2025-06-08T14:50:50+00:00
    Thanks Ramesh,
