How do you switch from offline mode to online mode in Windows 11?
2022-03-01T16:53:00+00:00
New to Windows 11 Pro and I am stuggling mightly with this issue.
Our organization requires several folders from our mapped network drives be set to "Always Available Offline".
However, when I'm connected and online, the only things that show up when accessing a mapped drives with folders/files that are set to be available offline are those files/folders set to be available offline.
Further, the drive status for any drive which has a file/folder set to be available offline is stuck on "Offline".
How do I change this to "Online"?
With Windows 10 Pro, this was rather simple and straight forward process.
From the file explorer ribbon, under the 'Easy Access' drop down menu, you could toggle from "offline" to "online".
In doing so, you would switch the mapped drive status to "online" and access to the entirety of drive's content would then be possible/granted.
How do I accomplish the same feat in Windows 11 Pro?
How do you switch to "online mode"?
PLEASE HELP.
2022-09-26T18:31:40+00:00
Did you ever figure out a solution to this? I'm on windows 11 and have same issue with offline files being the only ones I can access. when I log in on other machines everything is there. Any tips?
I found a work around but it's not a great one... more like discovering a glitch in the matrix, if you will.
On Windows 11, while connected/online, open the 'Control Panel' and select 'Windows Tools'.
Doing so will open a new and special 'File Explorer' window; different than the normal Windows 11 'File Explorer' window.
For some reason, the 'File Explorer' window that opens when you select 'Windows Tools' appears to be the 'File Explorer' from Windows 10.
From this window, naviagate to the drive where you have files set to be available offline and you'll notice that the 'Easy Access' drop-down menu is again present.
From the 'Easy Access' drop-down, you'll find the toggle to 'Work Online'.
I'll try to post some screenshots to show what I am talking about when I next have a few moments.
Stand-by.
60 additional answers
    2022-12-11T21:05:46+00:00
    Thanks just what I needed.
    It is very poor that they appear to have just discontinued the Offline Files feature. I have been unable to use my laptop to open files as they are the old version of the files I need!!!
    Your issue is exactly what I have experienced here.
    2022-12-11T21:15:20+00:00
    To make this easier for your end users, you can Search for "Windows Tools" app, and you can right click and add to the Taskbar as an icon so it's handy.
    2022-12-15T22:21:03+00:00
    Also see the discussion at https://answers.microsoft.com/en-us/windows/forum/all/restoring-windows-10-ribbon-on-win-11/2ddfb886-3ef9-4d61-a95c-ac38825bb30c:
    "SteveSXD
    Replied on October 4, 2022
    In reply to balloonie's post on October 3, 2022The old explorer is still there, if you open a run box and type control, hit enter to open control panel then press Alt+Up Arrow then Windows 10 explorer is back. Unfortunately, I don't know of a way of keeping it like this, for now I am just opening a couple of windows like this and trying to remember not to shut them down. Doesn't really feel like progress to be honest, typical MS, why not give people a choice instead of forcing this garbage that no one asked for...."
    2022-12-20T21:22:45+00:00
    Superb, thanks for this, much appreciated, and saved me having to drive back in to work !! Not sure why the Microsoft expert couldn't have said this much earlier in the thread, but very grateful to you for posting it.
