How do you switch from offline mode to online mode in Windows 11?
2022-03-01T16:53:00+00:00
New to Windows 11 Pro and I am stuggling mightly with this issue.
Our organization requires several folders from our mapped network drives be set to "Always Available Offline".
However, when I'm connected and online, the only things that show up when accessing a mapped drives with folders/files that are set to be available offline are those files/folders set to be available offline.
Further, the drive status for any drive which has a file/folder set to be available offline is stuck on "Offline".
How do I change this to "Online"?
With Windows 10 Pro, this was rather simple and straight forward process.
From the file explorer ribbon, under the 'Easy Access' drop down menu, you could toggle from "offline" to "online".
In doing so, you would switch the mapped drive status to "online" and access to the entirety of drive's content would then be possible/granted.
How do I accomplish the same feat in Windows 11 Pro?
How do you switch to "online mode"?
PLEASE HELP.
2022-09-26T18:31:40+00:00
Did you ever figure out a solution to this? I'm on windows 11 and have same issue with offline files being the only ones I can access. when I log in on other machines everything is there. Any tips?
I found a work around but it's not a great one... more like discovering a glitch in the matrix, if you will.
On Windows 11, while connected/online, open the 'Control Panel' and select 'Windows Tools'.
Doing so will open a new and special 'File Explorer' window; different than the normal Windows 11 'File Explorer' window.
For some reason, the 'File Explorer' window that opens when you select 'Windows Tools' appears to be the 'File Explorer' from Windows 10.
From this window, naviagate to the drive where you have files set to be available offline and you'll notice that the 'Easy Access' drop-down menu is again present.
From the 'Easy Access' drop-down, you'll find the toggle to 'Work Online'.
I'll try to post some screenshots to show what I am talking about when I next have a few moments.
Stand-by.
60 additional answers
  1. Les Ferch 10,361 Reputation points Volunteer Moderator
    2023-10-03T00:29:33+00:00
    If you want a little more convenient option to open the Windows 10 Explorer on Windows 11, there's this:
    https://lesferch.github.io/OldExplorer/
    And if you want to make the Windows 10 Explorer the default, you can do that with one of several available patch programs. For example, with StartAllBack, you would select the "Kinda 10" mode.
    2023-10-06T01:02:02+00:00
    Try the instructions in the video link below to set Windows 11 file explorer to look like Windows 10 with the "Easy Access" drop down that lets you toggle offline files off & on. If it looks just like Windows 11 after going through the stuff in the video, then right mouse click in the sort of a ribbon area and uncheck "Minimize ribbon" to get the ribbon to show up.
    install windows 10 file explorer on windows 11 machine - Google Search
    2023-11-08T14:41:12+00:00
    I have given up on Offline Files completely. The problem of not seeing all files while online, and only seeing icons of files and folders you can't access, is so frustrating. It has been going on for literally years. I started using Offline Files in the early 2000s, and the problem existed then, too.
    A few years ago I switched to FreeFileSync. It works well. The downside of this is that the path to all files changes to a local path. I have to close all those local folders and files, sync, then go to the network paths again. It is not a great solution and wastes time.
    If Microsoft were to come up with an actual working variety of Offline Files, I would gladly use it. But, until then, I cannot because, every time I do, I get trapped "offline" when I'm actually online.
  4. Deleted
