Same issue here and of course the files I cant open are for my taxes... Will have to open them on my laptop running Win2010 now. Another great OS upgrade/ downgrade by Microsoft!
Files have a brown box on their icon and dont open in Windows 11
What is going on here? There is no information anywhere so it obviously isnt a problem for everyone.
Most of my files stored on Dropbox now have a small brown file box icon on the lower left corner of the main icon for all MS Office files. They open perfectly well on the phone and a laptop running Windows 10 but not on my laptop running Windows 11.
I get an error message saying the program cant open it because the file is unsupported or may be corrupt.
Why the **** do they release an OS that doesn't work with their own programs??
Please help,
2023-04-16T19:46:39+00:00 -
2023-06-23T15:01:35+00:00 Is there a reply to this. I have the same problem and have lost thousands of files because of it this brown file box being placed on the files.
2023-06-23T15:07:49+00:00 Where is "sync service"?
Diane Poremsky MVP 17,526 Reputation points MVP Volunteer Moderator2023-06-23T20:39:56+00:00 Are they in OneDrive or Dropbox folder? Is the app running?
If you aren't sure, type the name on the start menu and open the app
Diane Poremsky MVP 17,526 Reputation points MVP Volunteer Moderator2023-06-23T20:46:10+00:00 What is the name of the parent folder your files are in?
Have you tried rebooting? For some people that is better than crashing File Explorer. If you have windows updates waiting ot be installed, definitely reboot and install them.
Are you signed into the app? Look in the notification area - click on the OneDrive icon (gray is personal OneDrive, blue is business OneDrive account) or Dropbox
