What are these brown box icons in left bottom corner of my files??
2022-03-07T21:29:56+00:00
Does anyone know where these small brown box icons came from and what they mean?? I suddenly have these little brown icons (looks like a small file box) on most of my files, Word, pdf, photos, etc. I've googled the daylights out of this and apparently lots of folks have the same question but no one has an answer. I hasn't affected my ability to open files but it's really annoying! (see pic below) Does it have something to do with my upgrade to Windows 11?
Thanks!
2022-04-23T00:35:08+00:00
Had this exact same issue today. The resolution was quick no reinstall. I'm on Win11, so perhaps that was a plus in this scenario. Here's the fix that worked for me:
  1. Open windows explorer <windows-key + e>
  2. If you're using OneDrive you should see something like "OneDrive - Personal" within the left-hand pane. If so, Right-Click to access the context-menu.
  3. You should see the menu-item: "Always keep on this device", select this.
  4. Recheck your desktop; no more brown boxes, yay!
204 additional answers
    2024-10-07T06:22:39+00:00
    If your items are in one drive then you can view them I noticed I found my missing files there
    2024-10-11T13:01:32+00:00
    After years of ongoing uncertainty, it is time for Microsoft to provide a clear explanation regarding the brown icon overlay boxes in Windows Explorer.
    It remains unclear how these brown box icon overlays differ from the standard OneDrive cloud icon and, more importantly, how they can be removed.
    The brown overlays are not only visually disruptive but also impede essential functions, such as displaying file thumbnails and previews in Windows Explorer and other programs. A definitive response is urgently needed.
    2024-10-18T04:36:39+00:00
    Thank You so much!! Greatly appreciated! What were those for? Do you know? and How did you know what to do? New to all this, computers and all this technical jibber-jabber; I'm curious to know the reasoning behind those little boxes.
    2024-10-29T20:47:43+00:00
    you. da. best! thanks.
    but how did it happen in the first place? what'd i do?
