What are these brown box icons in left bottom corner of my files??
2022-03-07T21:29:56+00:00
Does anyone know where these small brown box icons came from and what they mean?? I suddenly have these little brown icons (looks like a small file box) on most of my files, Word, pdf, photos, etc. I've googled the daylights out of this and apparently lots of folks have the same question but no one has an answer. I hasn't affected my ability to open files but it's really annoying! (see pic below) Does it have something to do with my upgrade to Windows 11?
Thanks!
2022-04-23T00:35:08+00:00
Had this exact same issue today. The resolution was quick no reinstall. I'm on Win11, so perhaps that was a plus in this scenario. Here's the fix that worked for me:
  1. Open windows explorer <windows-key + e>
  2. If you're using OneDrive you should see something like "OneDrive - Personal" within the left-hand pane. If so, Right-Click to access the context-menu.
  3. You should see the menu-item: "Always keep on this device", select this.
  4. Recheck your desktop; no more brown boxes, yay!
204 additional answers
    2022-03-09T01:55:51+00:00
    Hi JoeBrock1-
    Thank you for keeping me posted. Yes. that is actually the last resort and glad that it is now working fine.
    Let me know if there is further concern. Have a blessed day!
    Kevin B.
    2022-03-15T20:16:43+00:00
    I have the same issue and I also uninstalled and re-installed and after a few weeks it all returned. what is that icon? what does it mean? this is a persistent and prevasive Issue that I see frequently in forums like this and no one seems to know what it is or how to fix it.
    2022-04-06T21:55:05+00:00
    Hi JoeBrock1-
    I'm Kevin B. Windows user like you. I do apologize for the inconvenience, let me help you sort things out.
    Are you using OneDrive? If so, that icon is for OneDrive Files on Demand.
    Kindly try to log out and log back in to your OneDrive and see if it will address the concern.
    If the issue persists, go to settings > apps > apps and feature archive apps > turn off that feature and see if the box will disappear.
    Please let me know what will happen. Hope this will help and have a blessed day!
    Kevin B.
    Independent Advisor
    I followed this and made zero difference. Archive App features has been disabled. No change in brown box icon overlay on DropBox folders.
    2022-04-09T22:41:09+00:00
    I think I got it! I had the same issue with the brown box in the corner and kept getting an error message when I tried to open the file. Here is what I did:
    Settings>system>one drive>network. Then a message popped up saying it was shut off. Turned it on for private network sharing and all of the boxes turned into green check marks and I am now able to open them! Hope this helps!
