What are these brown box icons in left bottom corner of my files??
2022-03-07T21:29:56+00:00
Does anyone know where these small brown box icons came from and what they mean?? I suddenly have these little brown icons (looks like a small file box) on most of my files, Word, pdf, photos, etc. I've googled the daylights out of this and apparently lots of folks have the same question but no one has an answer. I hasn't affected my ability to open files but it's really annoying! (see pic below) Does it have something to do with my upgrade to Windows 11?
Thanks!
2022-04-23T00:35:08+00:00
Had this exact same issue today. The resolution was quick no reinstall. I'm on Win11, so perhaps that was a plus in this scenario. Here's the fix that worked for me:
  1. Open windows explorer <windows-key + e>
  2. If you're using OneDrive you should see something like "OneDrive - Personal" within the left-hand pane. If so, Right-Click to access the context-menu.
  3. You should see the menu-item: "Always keep on this device", select this.
  4. Recheck your desktop; no more brown boxes, yay!
204 additional answers
    2022-12-16T20:10:00+00:00
    Has MS addressed this problem?
    2022-12-21T21:59:43+00:00
    Yep, this worked. Thank you!
    2022-12-28T01:10:57+00:00
    RE: Resolution for brown folders blocking file access
    Thanks however, NO SUCH TEXT ""Always keep on this device"," <?> FYI using Window11
    2022-12-28T01:13:17+00:00
    David er.
    Open task manager, on the process tab right click 'Windows Explorer' and select restart
    NOPE no-worky,,,, keeps re occurring...
