What are these brown box icons in left bottom corner of my files??
2022-03-07T21:29:56+00:00
Does anyone know where these small brown box icons came from and what they mean?? I suddenly have these little brown icons (looks like a small file box) on most of my files, Word, pdf, photos, etc. I've googled the daylights out of this and apparently lots of folks have the same question but no one has an answer. I hasn't affected my ability to open files but it's really annoying! (see pic below) Does it have something to do with my upgrade to Windows 11?
Thanks!
2022-04-23T00:35:08+00:00
Had this exact same issue today. The resolution was quick no reinstall. I'm on Win11, so perhaps that was a plus in this scenario. Here's the fix that worked for me:
  1. Open windows explorer <windows-key + e>
  2. If you're using OneDrive you should see something like "OneDrive - Personal" within the left-hand pane. If so, Right-Click to access the context-menu.
  3. You should see the menu-item: "Always keep on this device", select this.
  4. Recheck your desktop; no more brown boxes, yay!
204 additional answers
    2023-02-25T15:23:13+00:00
    oh no!!
    2023-02-25T15:22:37+00:00
    Just tried that, but no luck. still the brown boxes of doom.
    2023-02-25T15:16:02+00:00
    I am having this same problem with synced folders from SharePoint that are I access through OneDrive on File Explorer. When things have that little icon, they won't open at all. I have to go back to SharePoint online to get the online version of the file. ^%&U%*Y****!!!!
    2023-02-21T18:18:29+00:00
    I turned off the apps feature, and the boxes disappeared. Worked like a charm! Thank you!
