Intel(R) Wi-Fi 6 AX201 160 MHz showing code 10 and code 43
2022-02-12T03:20:24+00:00
After updating to the most recent updates, my wifi isn't working. After watching in the driver, it shows me that my wifi driver is just unavailable and just showing either code 10 or code 43. I tried reinstalling the driver countless of times, enabling / disabling it and even tried to uninstall the most recent update which I suspect is causing the problem. But even without the updates installed, I still can't use my wifi.
    2022-12-15T18:47:33+00:00
    Thanks!
    It works. I fell myself crazy until I use you method!
    2023-01-03T15:53:58+00:00
    Помогло зайти в биос отключить WIFI и блитуз .Запустить ОС затем выключить и зайти снова в биос включить только WIFI
    2023-01-06T23:57:41+00:00
    For the love of god you saved my morning shift, thank you kindly sir!
    2023-02-05T14:37:42+00:00
    I tried all the solutions above and in the end, the network reset solution worked. As simple as that. I went to settings > network & internet > status - at the bottom of the page, network reset , reset now and come back in an hour. Power up your device and Voila ! Everything back to normal.
    Funny how we tend to break our heads when sometimes a simple solution is right under our nose
    Hope it works for all.
    2023-02-11T13:16:59+00:00
    Just found solution on Reddit
    Power off
    1. Unplug my charger
    2. Turn the laptop over(upside down)
    3. I had to locate a small pin sized hole on the middle right next to one of the screw holes.
    4. Use a paperclip to press the button and hold for 40 seconds.
    5. Power on
    6. Reconnect Charger
    Once powered on, I went to device manager and saw the Bluetooth tab(option) again. Then I switched my mouse from 2.4 back to Bluetooth.
    Still no change with the Wi-Fi as the yellow triangle was still there. So I disabled, then re-enabled. Poof, everything was back to normal.
    Maybe this will help someone in the future!
    I never ever replied to community but i login just to say thatr i love you
