Hi, did you Shutdown or go to Sleep, it is not the same :)
Intel(R) Wi-Fi 6 AX201 160 MHz showing code 10 and code 43
After updating to the most recent updates, my wifi isn't working. After watching in the driver, it shows me that my wifi driver is just unavailable and just showing either code 10 or code 43. I tried reinstalling the driver countless of times, enabling / disabling it and even tried to uninstall the most recent update which I suspect is causing the problem. But even without the updates installed, I still can't use my wifi.
2022-04-29T07:27:32+00:00 -
2022-06-10T15:31:54+00:00 I should mention I have a laptop with this problem so if you have a desktop I recommend turning your pc off on the wall and restarting. There seems to be a problem with sleep or hibernate states which manifests with wake on Wifi. So basically the chip does not reset on restart or power down, because it still has power.
2022-06-10T16:03:09+00:00 Hi, please check you Power plan and set wifi at maximum. I read that helps.
2022-06-20T00:11:59+00:00 A full SHUT DOWN fixed the problem with the network driver without any further action.
I only waited 2-3 minutes to start up again.
Note:
THE RESTART does NOT work.
disabling and enabling does NOT work.Thanks everyone!
Deleted
