Intel(R) Wi-Fi 6 AX201 160 MHz showing code 10 and code 43
2022-02-12T03:20:24+00:00
After updating to the most recent updates, my wifi isn't working. After watching in the driver, it shows me that my wifi driver is just unavailable and just showing either code 10 or code 43. I tried reinstalling the driver countless of times, enabling / disabling it and even tried to uninstall the most recent update which I suspect is causing the problem. But even without the updates installed, I still can't use my wifi.
    2024-07-09T17:37:53+00:00
    Hi! I have the same network card + Windows 11. You have already tried many things, even a hard reset. Everything was fine for a while and the problem kept recurring. I do not know what to do.
    2024-07-12T23:48:26+00:00
    Thank you thank you thank you I have been struggling with this for hours this finally worked Now what do I do Do I take it to geek squad after this Do I still have to and what kind of measures do I take from this not happening again!!! Thank you so much you are a blessing 🤗🤗🤗🤗🙏🙏🙏🙏🙏👍👍👍👍👍🙏.
    Pam Z
    2024-08-13T08:55:15+00:00
    System manufacturer : LENOVO
    System Model : 82SX
    2024-08-14T07:44:24+00:00
    I have the same laptop as you, I have the same issue every since I've gotten it, have you every found a fix for it?
    2024-08-24T14:14:04+00:00
    Thanks carlo it fixed my pc
