Intel(R) Wi-Fi 6 AX201 160 MHz showing code 10 and code 43
2022-02-12T03:20:24+00:00
After updating to the most recent updates, my wifi isn't working. After watching in the driver, it shows me that my wifi driver is just unavailable and just showing either code 10 or code 43. I tried reinstalling the driver countless of times, enabling / disabling it and even tried to uninstall the most recent update which I suspect is causing the problem. But even without the updates installed, I still can't use my wifi.
    2023-10-03T14:53:01+00:00
    Thanks. It solved my issue with wi-fi driver.
    Appreciated !
    2023-10-12T21:35:39+00:00
    Hello, I have the same exact problem and I tried everything that you stated here.
    My System Model is GF65 Thin 10UE and the manufacturer is Micro-Star International Co., Ltd.
    2023-10-18T14:27:52+00:00
    System Manufacturer ASUSTeK COMPUTER INC.
    System Model ASUS TUF Gaming F15 FX506LU_FX506LU
    2023-12-28T10:37:57+00:00
    Have tried all the solutions you stated,but the Intel(R) Wi-fi 6AX201 160MHz is not working.Please find the attached picture.
    2024-02-03T18:52:46+00:00
    Hey, I tried everything here and nothing has worked
    I’ve tried disabling and enabling it but nothing
    System and manufacturer are
    82A4 and LENOVO
