I also seem to be unable to get more Bsod dump files. Ever since reinstalling windows the system completely loses power without creating a file in MiniDumps, AND it can now boot and run under the Driver verifier settings Id been using. But the system still ONLY crashes when running Steam.exe, how could it be a hardware problem.
Help reading a Dump file
My Pc has a new found power loss issue during gaming it simply loses power and there are little to no error logs. I have logs about Drivers failing on every startup that I dont believe are related, and after I reboot from a crash I see error 41 Kernal Power, And Error 6008, Unexpected shutdown. However recently there was a shutdown wherre the top 1/4th of my display showed a BSOD error and created a dump file, which Im hoping will shed some light on my problem, but Im not sure how to open or read it.
(I suspect my issue is the PSU Voltage is lower than it should be which would be upsetting, its a brand new Revolt-X and I already just spent 3 months waiting on Powercolor to replace my Gpu, but my Psu was probably damaged at the same point)
2021-09-25T01:02:21+00:00
