yeah it happens to me, and makes fps games unplayable
roblox cursor issue
so like my mouse just goes off-screen, for example, if i go in first person and look up into the sky(pulling my mouse up), my cursor would just exit Roblox and into the white bar containing the exit button someone please help
Windows for home | Other | Search, touch, and mouse
2022-01-10T20:57:40+00:00 -
2022-02-15T10:24:17+00:00 this will be annoying if use more than one moniter i think the only solution is just to play the roblox from the website well i know the UWP will get you more performance but its not too much performance i know its annoying but its like that :(
i have this issue too
2022-02-15T10:26:54+00:00 try using one moniter instead of 2 it will help if your going to multi task then this is going to be very annoying
2022-02-19T10:42:13+00:00 pls find another solution this did not help for me
2022-02-21T00:11:02+00:00 yeah it happens to me, and makes fps games unplayable
I found a fix. You have to use the beta launcher
