roblox cursor issue
2021-08-18T01:44:26+00:00
so like my mouse just goes off-screen, for example, if i go in first person and look up into the sky(pulling my mouse up), my cursor would just exit Roblox and into the white bar containing the exit button someone please help
Windows for home | Other | Search, touch, and mouse
    2023-05-24T13:40:27+00:00
    Same thing happened with me and it's kinda getting on my nerves because everytime I move my mouse in first person I cannot do it because my mouse does this effect
    2023-05-27T17:43:51+00:00
    bro SAME
    2023-06-13T16:21:26+00:00
    2023-06-17T07:20:56+00:00
    Ok so, I have the same problem, and I dont know how to fix it, BUT, I know what causes it, and you maybe might know what to do, so the problem is that there are 2 cursors, a permanent one in roblox, and your normal cursor, which goes off the screen, to fix this you either need to find a way to remove your permanent cursor from roblox and only use your cursor, OR, to make it so your cursor doesnt intrerupt when you click in roblox, lmk if u find anything
    2023-07-03T23:54:46+00:00
    If you download Roblox from the internet it won't do it. But when you install it from the Microsoft Appstore it does it it's a bug. Try downloading it from the internet it will fix the problem.
