I always perform a clean install every time and currently have the latest driver installed.
HELP ME !!! VRChat.exe not responding UnityPlayer.dll caused a Breakpoint
On loading VRChat the white box for VRChat.exe comes up for 2/3 mins and then is not responding and closes. In the error log it mentions;
UnityPlayer.dll caused a Breakpoint (0x80000003) in module UnityPlayer.dll at 0033:89f976fb.
and;
No mono DLL path set. This app is either running IL2CPP, or the crash occurred before mono was initialized. I have been in contact with VRChat support for over a month and 40+ emails later and trying all sorts of things to try to fix it even fresh windows install. Support team have given in and ask me to file a bug report. Please see the attached pictures, links to error.log and crash.dmp file.
crash.dmp https://drive.google.com/file/d/1gP5D2VHWAERtSjJ3IcG4rf6p2wzxnHYh/view?usp=sharing
error.log https://drive.google.com/file/d/1YvT6DgECWvG7Pel3cnprAuYbaPzs3Dr2/view?usp=sharing If anyone can help please do.
2021-09-04T11:46:29+00:00 -
2021-09-05T12:58:17+00:00 Can you try a "clean boot" and see if it makes a difference:
https://support.microsoft.com/en-us/kb/929135
If a clean boot does resolve the issue there is a section in the article "How to determine what is causing the problem by performing a clean boot".
Reset the computer to start normally afterward.
As a general precaution create a System Restore Point prior to initiating a clean boot.
2021-09-05T14:48:05+00:00 I'm sure I've already tried this before with VRChat support, but I have given it another go today and unfortunately it hasn't made a difference.
2021-09-05T14:58:32+00:00 Can you provide the following information which may help determine any issue(s):
Windows Key + R > type msinfo32 in the "Open" box > OK > File > Save > then save as an .nfo file
Then make the resulting .nfo file available via OneDrive.
Also, can you do the following:
Windows Key + R > type eventvwr in the "Open" box > OK > expand "Custom Views" and then right-click "Administrative Events" > select "Save all events in Custom View As" and save as an .evtx file
Then make the resulting .evtx file available via OneDrive.
