HELP ME !!! VRChat.exe not responding UnityPlayer.dll caused a Breakpoint
2021-09-01T22:08:23+00:00
On loading VRChat the white box for VRChat.exe comes up for 2/3 mins and then is not responding and closes. In the error log it mentions;
UnityPlayer.dll caused a Breakpoint (0x80000003) in module UnityPlayer.dll at 0033:89f976fb.
and;
No mono DLL path set. This app is either running IL2CPP, or the crash occurred before mono was initialized. I have been in contact with VRChat support for over a month and 40+ emails later and trying all sorts of things to try to fix it even fresh windows install. Support team have given in and ask me to file a bug report. Please see the attached pictures, links to error.log and crash.dmp file.
crash.dmp https://drive.google.com/file/d/1gP5D2VHWAERtSjJ3IcG4rf6p2wzxnHYh/view?usp=sharing
error.log https://drive.google.com/file/d/1YvT6DgECWvG7Pel3cnprAuYbaPzs3Dr2/view?usp=sharing If anyone can help please do.
    2021-10-13T20:27:09+00:00
    OK, that is normal and the default.
    Can you provide a couple of the latest dump files to see if anything has changed.
    2021-10-14T17:24:43+00:00
    2021-10-16T17:05:39+00:00
    The error remains the same.
    Have you tried running the program in a different compatibility such as Windows 8 ?
    2021-10-16T17:24:02+00:00
    not sure if I have, or how to?
    2021-10-20T16:12:02+00:00
    If you right-click the VRChat.exe > Properties > Compatibility
    What is listed under "Compatibility mode" ?
