HELP ME !!! VRChat.exe not responding UnityPlayer.dll caused a Breakpoint
2021-09-01T22:08:23+00:00
On loading VRChat the white box for VRChat.exe comes up for 2/3 mins and then is not responding and closes. In the error log it mentions;
UnityPlayer.dll caused a Breakpoint (0x80000003) in module UnityPlayer.dll at 0033:89f976fb.
and;
No mono DLL path set. This app is either running IL2CPP, or the crash occurred before mono was initialized. I have been in contact with VRChat support for over a month and 40+ emails later and trying all sorts of things to try to fix it even fresh windows install. Support team have given in and ask me to file a bug report. Please see the attached pictures, links to error.log and crash.dmp file.
crash.dmp https://drive.google.com/file/d/1gP5D2VHWAERtSjJ3IcG4rf6p2wzxnHYh/view?usp=sharing
error.log https://drive.google.com/file/d/1YvT6DgECWvG7Pel3cnprAuYbaPzs3Dr2/view?usp=sharing If anyone can help please do.
    2021-10-08T06:35:59+00:00
    G-sync is disabled now, no change
    2021-10-08T15:10:58+00:00
    Do you have a fixed size paging file?
    2021-10-10T14:06:28+00:00
    I don't know what that is sorry
    2021-10-11T18:28:27+00:00
    Can you check here:
    Start > type advanced > click on "View advanced system settings" > click on "Settings" under "Performance" > Advanced > click on "Change" under Virtual memeory
    Is "Automatically manage paging file size for all drives" selected?
    2021-10-12T11:36:33+00:00
    yes the box is checked
