BIOS update done, no change
HELP ME !!! VRChat.exe not responding UnityPlayer.dll caused a Breakpoint
On loading VRChat the white box for VRChat.exe comes up for 2/3 mins and then is not responding and closes. In the error log it mentions;
UnityPlayer.dll caused a Breakpoint (0x80000003) in module UnityPlayer.dll at 0033:89f976fb.
and;
No mono DLL path set. This app is either running IL2CPP, or the crash occurred before mono was initialized. I have been in contact with VRChat support for over a month and 40+ emails later and trying all sorts of things to try to fix it even fresh windows install. Support team have given in and ask me to file a bug report. Please see the attached pictures, links to error.log and crash.dmp file.
crash.dmp https://drive.google.com/file/d/1gP5D2VHWAERtSjJ3IcG4rf6p2wzxnHYh/view?usp=sharing
error.log https://drive.google.com/file/d/1YvT6DgECWvG7Pel3cnprAuYbaPzs3Dr2/view?usp=sharing If anyone can help please do.
2021-09-29T08:42:34+00:00 -
2021-10-01T17:44:31+00:00 When you did a fresh install of Windows was it a "clean install"?
2021-10-01T17:51:45+00:00 September 1st I think or close to then
2021-10-03T03:08:52+00:00 Just to make sure, it was a clean install?
2021-10-03T15:02:06+00:00 yes, drive formatted as well
