thanks for the information, ill check if there are new updates now.
KB5005565 - Issue accessing Shared Printer
One of the systems(Windows 10 Pro - 21H1) in domain had a shared printer (Epson LX-350) which was inaccessible over the network, print works locally without an Issue.
Print was fired from the network system but ends without an error, one of the error logs in administrative Events suggested error 372 and so followed every step as suggested for “PrintNightmare” but unfortunate nothing worked positive. Tried removing the printer from the network desktop and tried to add the shared printer. Now it wass understood that the issue is something restricting the shared printer to be accessed thru any version of Operating System (Tried with another Win 10 & Win 7 Sp1).
Uninstalled KB505565 and was accessible, What is the technical reason and any work around?
2021-10-22T08:06:11+00:00 -
2021-10-22T08:12:20+00:00 Even after 153 people have come up with the same issue do you still deny that there is an issue with the patch.
2021-10-22T08:22:07+00:00 Even after 153 people have come up with the same issue do you still deny that there is an issue with the patch.
right, there is even a couple of videos (or more) on youtube already regarding this issue with 46k+ and 29k views. I assumed those viewers are also searching for an answer.
2021-10-27T08:16:14+00:00 Hi guys its now october 27. Is there any fix to this problem yet? I'm tired of uninstalling this update.
2021-10-27T08:23:31+00:00 Hi guys its now october 27. Is there any fix to this problem yet? I'm tired of uninstalling this update.
no solution yet as of now, been updating everyday hoping that it will fix the issue.
good for you, at least you can still uninstall.
