It's been 3 weeks and this problem has still not been resolved. Local printers of any brand are still NOT shared with other stations on our network because of KB5005565. I turned ON updates and KB5005565 was (once again) re-installed....and (once again) the printer sharing issue returned. Had to (once again) un-install the update and the printers work fine. We need a long-term solution for this issue. PLEASE!
KB5005565 - Issue accessing Shared Printer
One of the systems(Windows 10 Pro - 21H1) in domain had a shared printer (Epson LX-350) which was inaccessible over the network, print works locally without an Issue.
Print was fired from the network system but ends without an error, one of the error logs in administrative Events suggested error 372 and so followed every step as suggested for “PrintNightmare” but unfortunate nothing worked positive. Tried removing the printer from the network desktop and tried to add the shared printer. Now it wass understood that the issue is something restricting the shared printer to be accessed thru any version of Operating System (Tried with another Win 10 & Win 7 Sp1).
Uninstalled KB505565 and was accessible, What is the technical reason and any work around?
2021-10-07T19:20:07+00:00 -
2021-10-07T19:21:02+00:00 It's been 3 weeks and this problem has still not been resolved. Local printers of any brand are still NOT shared with other stations on our network because of KB5005565. I turned ON updates and KB5005565 was (once again) re-installed....and (once again) the printer sharing issue returned. Had to (once again) un-install the update and the printers work fine. We need a long-term solution for this issue. PLEASE!
Deleted
2021-10-07T22:04:15+00:00 Microsoft is an absolute nightmare! But install the latest update and I found it fixed the issue.
2021-10-08T13:10:23+00:00 I just tried to perform all of the most recent updates and that unfortunately did not work for me.
It is just not right that we have to then go into the registry and attempt to perform an edit to fix this issue.
This is just unacceptable!
The print nightmare debacle continues!
M$ - please get on this and offer a correct fix!
