KB5005565 - Issue accessing Shared Printer
2021-09-16T06:10:47+00:00
One of the systems(Windows 10 Pro - 21H1) in domain had a shared printer (Epson LX-350) which was inaccessible over the network, print works locally without an Issue.
Print was fired from the network system but ends without an error, one of the error logs in administrative Events suggested error 372 and so followed every step as suggested for “PrintNightmare” but unfortunate nothing worked positive. Tried removing the printer from the network desktop and tried to add the shared printer. Now it wass understood that the issue is something restricting the shared printer to be accessed thru any version of Operating System (Tried with another Win 10 & Win 7 Sp1).
Uninstalled KB505565 and was accessible, What is the technical reason and any work around?
    2021-09-28T20:21:23+00:00
    Cannot find the way to make it work with this update.
    2021-09-28T21:44:00+00:00
    Did you try changing the regkey as per the article I shared from September 24? (RpcAuthnLevelPrivacyEnabled)
  3. Deleted
    2021-09-30T08:49:06+00:00
    PLEASE STOP FORCING THIS UPDATE UNTIL THERE IS A PATCH OR FIX! I am spending my time unistalling the update and pausing updates, for the computers to override this and update anyway.
    2021-10-01T10:41:26+00:00
    Shared Workgroup printers have stopped working as well. Removing this update (KB5005565) corrects the problem. Is there a way to hide this update or is there a fix in the works?
    I am also having same situation at my office we also uninstalled that update now it's working fine but next day again that update installed so facing same issue
    Microsoft
    Please findout permanant solution
