DTS:X Ultra Not working
2021-04-05T05:56:31+00:00
Hello Everyone,
I have Asus TUF F15, and my DTS:X Ultra keeps showing :
"Please connect external speakers to use DTS audio controls.
Please connect a Headphone to use DTS audio controls"
I have tried mostly method available online but noting seems to be working for me, So finally I reinstalled the windows and DTS:X started working but after a day same thing started happening again. I have latest Windows 10 Home and Latest Drivers. Rolling back driver doesn't work too.
If any one have solution then please share.
Thank you
    2021-06-26T16:03:21+00:00
    I have now tried a different method to fix the issue which is Disable updates for Windows from registry (regedit). And then run the MediaCreationTool21H1 and It will fix the DTS:X Ultra issue and you will continue receiving Security updates even after disabling Windows Update. Also I have not used Bluetooth Media Devices since after the fix.
    How to stop automatic updates on Windows 10 | Windows Central https://download.microsoft.com/download/d/5/2/d528a4e0-03f3-452d-a98e-3e479226d166/MediaCreationTool21H1.exe
    Please check and let me know if it works for you too or not.
    Thank you
    2021-06-26T17:44:57+00:00
    I disabled something called " AMD Audio CoProcessor" from device manger and restarted my laptop and then DTS:X Ultra worked again!!
    And then after restarting
    2021-06-27T09:01:37+00:00
    That's good to know but my PC is intel based So that's not the problem in my case.
    2021-07-01T17:34:01+00:00
    The win update changed this Realtek console too. I can not enhance the volume from it anymore. It died like DTS UltraX did.
    2021-07-01T17:55:50+00:00
    If its showing like this, then please check DTS:X Ultra it should be working now.
