DTS:X Ultra Not working
2021-04-05T05:56:31+00:00
Hello Everyone,
I have Asus TUF F15, and my DTS:X Ultra keeps showing :
"Please connect external speakers to use DTS audio controls.
Please connect a Headphone to use DTS audio controls"
I have tried mostly method available online but noting seems to be working for me, So finally I reinstalled the windows and DTS:X started working but after a day same thing started happening again. I have latest Windows 10 Home and Latest Drivers. Rolling back driver doesn't work too.
If any one have solution then please share.
Thank you
    2021-06-17T09:01:44+00:00
    Hello, I have tried reinstalling Drivers but didn't worked for me. May I know what Windows version you are on?
  2. Deleted
    2021-06-20T04:05:42+00:00
    We have the same issue, and i got low audio.
    I  already fix the low audio by uninstalling and tick the delete the driver software
    DTS APo4X
    DTS audio Effect
    DTS Audio Hardware
    Uninstall then restart then check if your low audio is fix
    But the DTS Ultra is still not working
    2021-06-26T14:07:46+00:00
    Yes I also have the same problem.
    It always shows like this below.
    Whether I plug in or not in, it always stays like this
    2021-06-26T15:06:38+00:00
    Hi Ayush
    Actually we need a plugin or software that can increase some volume of our PC
    use RealTek Audio Control (if already have and not showing equalizer settings uninstall it and install it again) that will also helpful
    APP LINK
    https://www.microsoft.com/store/productId/9P2B8MCSVPLN
    set the equalizer as screenshot shown below:-
    Save this Preset by clicking save button and it will work fine
