Problem with Windows 10 ver. 21H1 -- all audio input/output devices missing in Sound settings, red X on volume icon
2021-05-19T09:59:57+00:00
For 2-3 days, I am getting no sound at all from my several audio devices/Windows computer here - I have TWO monitors with HDMI audio, plus headphones jack connected to motherboard audio card. I was able to fix it one time by doing lots of tinkering in Device Manager, but I am unable to replicate the fix a 2nd time.
So, asking here.
System is a desktop PC, running an Intel Core i3 Haswell CPU (2 cores, 4 threads), 16 GB of DDR3 RAM, on a ASUS H81M2 motherboard, GPU is AMD Radeon R9 390 (8 GB). Audio card is the built-in Realtek. 1 Crucial SSD, plus 2 HDDs -- WD and Seagate. Logitech Full HD webcam , Logitech wireless mouse, wired Razer keyboard.
The volume icon in lower right (Notification area) shows with a red X. In Settings of Windows 10 OS, Sounds, NO input or output devices show at all.
No sounds possible in any software, i.e. browser, actual OS does not make the Start Windows sound like it used to/etc.
Also, no recording or voice chat possible with my Logitech webcam (which has a stereo microphone), so no Skype, Viber/etc voice calls.
In Device Manager, nothing shows wrong - all audio, system devices appear to be working fine. In AMD Radeon GPU settings, nothing wrong shows either.
I tried the Windows 10 Sound Troubleshooter, but it unfortunately says it cannot identify the issue.
What can I do to fix this?
(Please do not suggest a reinstall Windows OS or Reset OS, I cannot do those.)
    2021-07-24T14:19:23+00:00
    Finally fixed!?
    Guys check out the registry fix pointed out by @Todd LaRiviere over here!
    I posted a PowerShell script based on that there as well :)
    Works for me too!
    It is very sad it look over 4500 views of my thread for a proper, correct & working solution for the issue.
    Hopefully, I won't get any such issues anytime soon, as I guess then I will need 10K+ views to get a fix, or worse...
    2021-07-24T14:28:40+00:00
    Hi FinderAUT,
    The registry trick solved it. I have audio on start up. It also solved another issue which HP also asked me to format my hard disk and re-install Windows, pressing on the Fn+Esc buttons would not open the HP System information windows that shows everything about your notebook including the serial number.
    I have closed two tickets in one go. Thanks you all for the kind help. If it doesn't work tomorrow. I will still post here ;)
    But ... MS ... really ?!!
    Yes, really!
    I have had much worse with Windows 10 updates, this one was a fairly harmless, although annoying bug. :)
    2021-07-30T11:25:50+00:00
    The registry fix didnt work for me =/
  4. Deleted
    2021-08-15T20:13:41+00:00
    Im having the same problem, when i try to update drivers it says there was an error and the troubleshooter does nothing, if you get an answer please contact me about it because i cant find a solution
