System restore mysteries / shadow copies etc
2021-04-22T05:04:50+00:00
New Windows 10 user here.
Have Googled/Binged around and still a bit puzzled about this.
So, System Restore is defaulted to "Off" in Windows 10. I understand some of the reasons for this, but still find it a useful tool.
(I left it like that, since it's still fresh and can basically just factory reset at this point)
Restore settings mention "using system protection on a drive that contains system image backups will cause other shadow copies to be deleted faster than normal"
OK. I'm not sure how fast "normal" is meant to be...
My Windows 10 came with Dell's SupportAssist installed, which apparently has its own recovery tools. Using it to download/install a few drivers, I noticed it had enabled Windows' System Restore by itself and created some restore points there.
(This came in useful because SupportAssist's driver updates resulted in a BSOD every time! I'll be uninstalling it...)
What set me wondering though, is I later noticed some errors in Event Viewer
"The shadow copies ... were aborted because the shadow copy storage could not grow due to a user imposed limit"
So it's already full?
8.90GB was set aside and I've barely done anything besides customise my user account!
Installed nothing!!
I then checked and all my restore points had gone too
This was strange because there haven't been any Windows - or even driver - updates in the meantime (which is usually the reason against keeping old restore points, for compatibility etc..?)
So I'm not getting shadow copies, and I'm not getting restore points...
What was more odd, was system restore was saying there were no restore points, but Current Usage showed 400-600MB in use.
What is this being used for?
Are they all these functions competing for the same space?
(and is this space barely enough for more than 1 of them to work properly?)
I don't really understand a great deal about system image backups, shadow copies, or restore points generally... I just know I should be backing up in some way.
Ideally in a way I don't have to mircomanage...
So hopefully someone could explain
System Image Backup
  • I can just reset to factory settings / reinstall Windows can't I, if things got really bad?
    Are there any likely cases where I wouldn't be able to?
    Is there any advantage (for the average Joe) in making a separate recovery drive to boot from?
> When the above warning mentioned a drive with "system image backups" (plural), what did it mean?
Is Windows automatically making many new system images itself?
Are they available to me?
(beyond the factory reset)
Shadow copies
  • Where can I find these / how can I access them?
    As long as I'm backing up my files regularly, I should mostly be fine.
    But it would be nice to get back the *exact* content I lost in the event of a crash. So how do I do this?
System restore
  • I'd like to have something with this functionality, but not if it's preventing the above functions from working.
    And I'm not into backing up my whole system to another drive on a daily basis, that seems like a lot of hassle
So basically, what's the best practice for low-effort safeguarding in the event of a failure to boot / hijack / loss of data etc?
I'm more confused than ever now
(I haven't noticed the shadow copy error in the last few days, and a new restore point was created. But I don't expect either to last like this for long...)
2021-05-04T01:22:14+00:00
(1) Your ReagentC shows partition 4 to be the Windows Recovery Environment partition. Shift+Restart will reboot to its recovery tools ("Choose an Option" screen). Normally, the computer also goes there when it has failed to boot Windows three times in a row. But going by that article I found, your computer will go to Partition 6 instead...
https://www.dell.com/support/kbdoc/en-in/000177401/restore-your-system-using-dell-supportassist-os-recovery
Restore your system using Dell SupportAssist OS Recovery
I don't see it saying it is making images or even just doing an independent backup & restore of user files. All I see is that you can do a factory reset (to the version of Windows that is on partition 5) or a fresh install of the latest Windows 10. You don't really want a factory reset after you've advanced to a greater version of Windows. It not only brings back the old version but also all the pre-installed Dell/Microsoft apps you've uninstalled along the way. And a fresh install of the latest version of Windows keeping files is what a regular reset will do anyway (without Dell's help). In either case, it will allow you to backup user files in concert with the reset & restore them afterward (but not apps). But the files will need to be accessible, i.e., whatever caused the catastrophe better not have messed with them. That's how I read it.
A Windows system image is superior because files, apps, & settings all are in the image, & apps that were deleted remain deleted when the image is restored. Also, Firewall rules are restored to that day. Only the ones you've changed since then will have to be changed again. And system images don't take terabytes. My three together occupy just 83.1 GB. A 3rd-party app could compress them even more...
That day I had to restore an image, everything was back as/of the date the image was made. But the choice is yours. And now I think your setup does possibly survive an upgrade-install because things work through BIOS & partition 6 instead of messing with the Windows recovery partition. But I really can't say for sure.
(2) That's right, Disk Management can't move a partition, & it can't expand a partition except into unallocated space immediately to the right of it. That's why a 3rd-party app is needed, but there's a bunch to choose from. It would have been nice had Dell decided to give us stuff Windows didn't already have on its own, but they didn't. If they ever do give us a partition manager, it likely will only do what Disk Management can already do.
(3) Yep, my DCOMCFG looks just like yours. Let us hope the VSS errors stay gone with Support Assist. But they almost sounded as if they could be ignored anyway. It certainly didn't keep you from getting a ton of shadow copies.
2021-05-02T23:01:05+00:00
DISKPART> List Part
  Partition ###  Type             Size      Offset
  Partition 1    System         250 MB  1024 KB     <<<EFI system partition
  Partition 2    Reserved      128 MB    251 MB    <<<MSR (Microsoft Reserved)
  Partition 3    Primary        222 GB     379 MB    <<<Windows partition
  Partition 4    Recovery      990 MB    222 GB     <<<Recovery Environment partition
  Partition 5    Recovery        13 GB     223 GB    <<<Factory reinstall partition
  Partition 6    Recovery    1309 MB    237 GB    <<<Or is this the RE partition?
Let's see "ReagentC  /Info" at an Admin Command Prompt. It will point to either partition 4 or 6 as the active Recovery Environment partition (Shift+Restart goes there)...
C:\WINDOWS\system32>ReagentC /Info
Windows Recovery Environment (Windows RE) and system reset configuration
Information:
    Windows RE status:         Enabled
    Windows RE location:    \?\GLOBALROOT\device\harddisk0*partition4*\Recovery\WindowsRE
    Boot Configuration Data (BCD) identifier: f8d976fc-df94-11ea-b1d0-74e6e2074932
    Recovery image location:
    Recovery image index:      0
    Custom image location:
    Custom image index:        0
REAGENTC.EXE: Operation Successful.
I think yours is partition 4 like mine. Then both partition 5 & 6 are expendable as soon as you begin to make system images of your own. I guess we could put a letter on partition 6 to see what's in it first...
DiskPart
Select  Disk  0
Select  Part  6
Assign  Letter=X    <<<Put letter X on partition 6
Exit
DIR  X:\  /a  /s       <<<Show contents of X:. Remove "/s" to show just the root directory.
DiskPart
Select Vol=X
Remove  Letter=X    <<<Remove the letter X
Exit
Partitions 5 & 6 can be deleted with DiskPart. Then a 3rd-party app will be required to move partition 4 fully rightward over the 14.3 GB of newly unallocated space. Finally, Disk Management can expand C:partition into that space. But we'd want you to be comfortable with Windows system images of your own (onto an external HDD) before doing so. I think Greg gave you instructions how to use Macrium Reflect. And that could indeed be worthwhile. But I am still a believer in Windows own image maker...
To backup the entire computer, make a Windows system image backup. It makes a backup of all the Windows partitions required to boot & run Windows:  EFI, MSR, Windows (C:), & Recovery. If you've got additional partition(s), they will also be offered for inclusion. (But likely that Dell factory reinstall partition won't be offered). A 2 TB external HDD is large enough to never fill with images. An 8 GB flash drive should be large enough to hold a Recovery drive (used to restore an image).
I make one after each new OS Build comes in & runs well, & I keep the last three...
I rename the computername folder which is inside the WindowsImageBackup folder (by appending the OS Build to it) in order to keep them separate & distinct. All three will be offered during the restore process.
Make it at "START, Settings, Update & Security, Backup, Go to backup & Restore (Win 7), Create a system image". Afterward, make the Repair Disc or (even better) ask Cortana for Recovery Drive to put it on USB. That can be used to do a restore. Then see the following to know how to restore one...
https://answers.microsoft.com/en-us/windows/forum/windows_10-update/how-to-restore-a-windows-10-system-image-to-an/e20992ca-5641-4f7c-bb09-3895d0732162
How to restore a Windows 10 system image to an existing or larger storage device
https://www.winhelp.us/restore-a-system-image-in-windows-7.html
Restore a System Image Backup in Windows 7, 8, 8.1 and 10
Note: That is an informative 3rd-party site, but I know nothing (good or bad) about any downloads or links that are there (or anywhere else).
If your external hard drive (or the internal one I guess) is a Seagate or Maxtor, there will be a free version of Acronis True Image at their site. Seagate calls it DiscWizard. Macrium Reflect, AOMEI Backupper & others also offer free versions of their image makers. These 3rd-party apps are quicker, make more compact images, & are more flexible in use. But the Windows version works in under 15 minutes on my small & uncomplicated system. I must add, DiscWizard's Bootable Media (to restore an image when Windows won't boot) requires a Mouse to operate. Plug one in, & it is instantly recognized.
61 additional answers
    2021-05-04T18:15:43+00:00
    Great, thanks so much for the elaboration
    So we think the Dell tool is mostly duplicative of Windows' restore options...
    Only, it lets you back up files too (which someone should hopefully be backing up themselves anyway) - and seems to allow me to perform a factory reset, which I otherwise might not be able to do in future, without this partition.
    I think I might keep it around for that last reason alone - there's a chance I may totally break something unknowingly, and not discover until much later!
    Also, if I wanted to sell this, restoring it to factory settings might come in useful...
    My issue with the firewall rules, was a system image may restore them to how I left them, but it defeats the point if Windows then unilaterally changes them back again soon afterwards.
    There's almost no benefit in fine-tuning them and capturing them in a system image if this is common behaviour...
    (But that's just one of many settings, others would hopefully stay put...)
    But I can certainly see the benefits of a system image, and like you I would lean towards the Microsoft tool (I've used it in the past). It seems they're trying to encourage us to use the fresh install route though.
    I was/am a bit wary of fresh install, but if this is as described (doesn't touch user files or settings) then I may chance my luck on that, when the time comes.
    This depends on all Windows releases being stable though; I have no experience of this yet, but have heard various reports that they sometimes aren't!
    I'll mull this over a bit longer (you've given me so much to think about, thank you so much).
    One last thing...
    I had looked into the 8GB flash recovery drive some time before making this thread, though can't remember a whole lot now.
    Assuming I hadn't made any system images, would the flash drive bring any other benefits beyond what my existing recovery partitions do?
    2021-05-04T21:30:31+00:00
    You are welcome. Right, important downloads & user files should be backed up on a regular basis & onto separate media. An HDD crash takes out all partitions, so put backups onto an external drive or onto OneDrive or even both. A Windows system image backup includes them in its image, & you needn't restore the whole image to get them back. The image can be mounted for individual files to be copied off it. As I understand SupportAssist OS Recovery, it doesn't backup files except at the time you use it to do a reset (whether to factory state or latest Win 10). Then it makes a copy of the files to be restored after the reset is done. That's how I read it. And I think you've said you aren't using Dell's separate Backup & Restore app (which likely would mimic Windows' own capabilities anyway).
    When selling the computer, likely the buyer will want it to work with the latest Windows version not its factory version. And you can clean off your files by doing a normal Windows reset or a clean install. I don't think difficulty with Firewall settings staying put is an argument against Windows system image backups. But, that's right, I wouldn't resort to one simply to revert Firewall settings.
    A Recovery flash drive provides an external recovery environment with many tools not just System Image Recovery. It has all the tools of your internal Recovery partition (Shift+Restart). Another external recovery environment is found on Win 10 Installation media. You would boot to it & choose "repair your computer" instead of to install. It is good to have an external one in case the partition will not work some day. Also, the external ones will ask for your Microsoft account password less often. It is best, though, to remake the Recovery flash drive &/or the Win 10 installation media each time a new Windows version comes in, You want it to match or exceed the version of Windows that is installed on the computer.
    2021-05-05T17:05:47+00:00
    Much appreciated PCR, I'll reread the whole thread and mark one of your fantastic replies as the answer (will try to choose the most appropriate!)
    *Thanks to Greg too, I've bookmarked his guide as well
    Hopefully I'll be able to start using this thing for fun one of these days~
    Turning it on just now, it wouldn't boot but just gave a black screen, with the power light staying on.
    The only route out was holding down the power button for a dirty reset.
    (Event Viewer is hard to read with the aforementioned system clock being off by so many hours - which confuses the logs slightly - but showed nothing out of the ordinary)
    I guess this is something I'll have to take to Dell forums...
    It shouldn't be acting up like this, since I've still barely touched it!
