intel usb 3.1 extensible host controller not present in device manager
2021-04-18T19:39:03+00:00
Hello Hello,
Hopefully one will be able to help me. I bought an external ssd (crucial x8) i have a laptop with a USB C 3.1 Gen 2 and when i check usb controllers in device manager i only have the 3.0 usb host. look at the screen cap please . The x8 promesses up to 1050mb/sec but since windows sees my 3.1 gen 2 type c usb as a 3.0 usb im only getting half the speed .. I d like to get full speed .. any genius in the room pls ive tried many options with no success.. (going in bios , reinstalling this and that, update drivers..) I just cant get the 3.1 controllers driver to load or else plss plsss help Thank you
    2021-04-24T07:07:35+00:00
    That is normal. Windows is recognizing it as an external drive. It is the same as mine. I tried to paste in an image but the web site won't keep it. Tried two different browsers.
    JohnD
  2. Deleted
  3. Deleted
    2021-04-24T10:33:00+00:00
    Hi are you able to see which file or files are responsible for handling your USB connections. I’d really like to get my hands on that USB 3.1 extensible controller so I can try it.
    Thanks John
    2021-04-25T11:54:16+00:00
    Hi Louis,
    You are really making me work. This is the information on the controller I got from DevManView, a great little tool from Nirsoft. I hope it helps.
    JohnD
    Device Name       : @System32\drivers\usbxhci.sys,#1073807361;%1 USB %2 eXtensible Host Controller - %3 (Microsoft);(Intel(R),3.1,1.10)
    Manufacturer      : Generic USB xHCI Host Controller
    Service           : USBXHCI
    Device Type Code  : USB
    Device Type Name  :
    Device Instance ID: PCI\VEN_8086&DEV_A36D&SUBSYS_8458103C&REV_10\3&11583659&1&A0
    Location          : @System32\drivers\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,20,0)
    Capabilities      : 0x00000000
    Config Flags      : 0x00000000
    Disabled          : No
    Connected         : Yes
    Device Registry Time 1: 11/4/2020 6:42:47 PM
    Device Registry Time 2: 11/12/2020 12:35:24 AM
    Drive Letter      :
    Container ID      : {00000000-0000-0000-ffff-ffffffffffff}
    Driver Description: USB xHCI Compliant Host Controller
    Driver Version    : 10.0.19041.662
    .inf File         : usbxhci.inf
    .inf Section      : Generic.Install.NT
    Driver Date       : 11/16/2020
    Driver Registry Time: 12/11/2020 4:39:30 AM
    The drivers are: (1) \Windows\system32\ USBXHCI.SYS and
     (2) \Windows\system32\UMDF\UsbXhciCompanion.dll
    I also found another driver in there belonging to my antivirus program (ESET NOD32) which really surprised me. I guess it wants to know when any device is connected on that USB bus. I know a message pops up when that happens.
